do i need camber adjusters??....
Old Apr 10, 2003 | 07:02 PM
gdatw019's Avatar
just so u know i have searched the forum and i would just prefer advice specific to my question...i just ordered a set of H&R Sport Springs and a friend just told me i need to get camber adjusters to prevent massive tirewear and i dont want anything drastic happening to my tires even though ill change them out sooner or later but neways do i need them and if so both front and back?and i guess i know i need an alignment right after too...but yea neways..thanks for the advice in advance
Old Apr 10, 2003 | 07:24 PM
TLlikeWHOA's Avatar
nope...i got a 99 TL with H&R sport springs....you dont need a camper kit or anything
your gonna love how they look...i kno i do ! Good Luck
-Eric
Old Apr 10, 2003 | 07:33 PM
gdatw019's Avatar
i would think it would still increase the wear of the tires because it changes the camber to sooomme degree..right?
Old Apr 10, 2003 | 08:05 PM
2001TL4KCdude's Avatar
Oracle Apps/Database Dude
make sure you get it aligned after you drop. you should not need a camber kit. How many miles on your TL?
Old Apr 10, 2003 | 08:44 PM
gdatw019's Avatar
little over a thousand its an 03 tlp
Old Apr 10, 2003 | 09:37 PM
Alexxx's Avatar
Get it checked, and if there is a camber, then get a kit. Every car is different with H&R Sports.
Old Apr 10, 2003 | 10:00 PM
Tatewaki's Avatar
Make sure you do the alignment 1-2 weeks after the install. The springs will sag a bit after initial install then stablize. The drop will be a bit more once it's settled. Then at that time you can do the alignment
Tatewaki
Old Apr 10, 2003 | 10:12 PM
gdatw019's Avatar
so i should go ahead with the install and 1-2 weeks after when the springs settle get an alignment along with gettin the camber checked as well...?
Old Apr 11, 2003 | 12:09 PM
hurricanevez's Avatar
when you get it aligned, if its a good place, they should give you a specific camber degree for each wheel, anything more than a degree and a half off and you have the potential for some funky tire wear, so wait until after you align to decide if you need a camber kit
Mike734
Dec 10, 2021 01:25 PM
emailnatec
29
Sep 28, 2018 04:27 PM
Jul 16, 2017 07:33 AM
lanechanger
Oct 13, 2015 10:56 AM
