Do ALL Transmissions have problems?
Sorry if its been asked alot, but I did do a search and couldn't find a definite answer.
Does anyone know if ALL (every single one) 2nd gen TL trannys have the failure problem? Or is it just luck of the draw? If it is luck of the draw, what are the chances of getting one that wont fail? (not won't fail for forever, but will last a reasonably long time)
P.S. Do the other cars in Honda's line-up that use this transmission also experience problems? Such as the 7th gen Accord, Odyssey, etc.
if i had to guess id say yes, but its luck of the draw. ive had 4 failures while some have had none
as for the rest of their line up?? up untill 04 yes they were all affected (odyssey, pilot accord, mdx all with the V6), we will see if the 05' and 06's are affected soon too
Originally Posted by kuhdoffi
well i guess in the long run its better to get the 4 speed spend a bit more for petro but i jsut dont wanna replace the trans.
so wich one do u think can handle more power ?
Ok, I'm probably going to jinx myself here, but I have a little over 61,000 miles on my 03 TL-S, bought in April of '02, and I have never had any issues with my tranny, took it in for the recall and they said it looked good as new. I am in no way easy on this car either. I would say itis just luck of the draw.
i've said this before but I think we should create a list tranny shops that can build reliable transmission for our cars. Its a shame to waste a car whose engine can last 400K (if maintained) but comes with tranny that lasts < 100K.
Originally Posted by SwampGas
...neither did I. Took it in for the 2nd gear recall around 65k and noticed slippage after that (Acura says the timing is a coincidence). A month later the Acura mechanic says those 3 magic words: internal transmission failure.
One question - are there any internal changes to the new transmissions they are putting in?
Originally Posted by MikePA
Bobby Rahal?
Green one with the dent in the rear passenger door and the funky XM antenna = me
Acura called and I got it back today.
Smooth 1 to 2. Very rough 2 to 3. So-so 3 to 4.
Got the new tranny and new ECU.
I noticed the same thing... I would not call it normal... I would call it what it is... I got rid of my car at 83000 miles. I figure the warranty was going to be gone soon, the car would need the timing belt replaced, tune up, brakes,etc. I decided it was not worth keeping
mada51589
Jan 9, 2025 04:40 PM
Mike Bertram
Sep 10, 2015 09:27 AM
HeloDown
Sep 8, 2015 06:51 PM
You do realize you just JINXed your self!
