Dirty engine compartment
Hi everyone!
I live in the Houston area, and the for the past couple of days, we got some crazy ass rain.
Anyways, I have a REALLY dirty engine compartment now....muddy water spots on EVERYTHING. Any quick and easy suggestions to get it clean (spray it down with a hose)? I know Acura dealers offer engine compartment cleaning, but it costs like $100.
Thanks in advance.
G
Thanks in advance.
G
Guest
Posts: n/a
heres how to clean an engine hose it down to get the big dirty stuff off then take Simple Green and spray it over the engine bay let it set for about five minutes then hose off and your done, if its real dirty you might need a brush....
hope this helps
hope this helps
Thanks for the advice tls260.
So, basically it's ok if all the other components (hoses, wires, etc.), since spraying down the engine would get everything else wet. Do I just use the simple green all over after the spray down, pop the hood open, and let the Houston sun bake the excess water off for a few minutes?
Could I use the same procedure for the sound insulation on the hood?
Just paranoid that there will be some small component that will get rusty or something.
G
G
Received 1,080 Likes
Unless it's caked on mud, spraying down the whole engine is not needed.
First, take a vacuum and suck out any of the dust and dirt you can pick up. Then, take some Simple Green and spray it on a rag and wipe down the dirty areas. I use one of those dash vent detailing brushes to get into the tight spots.
Peach Tea
one of my friends sprayed water into the engine bay of his eclipse and it wouldnt start. i suggest wipe it down. but hey, at least his engine is clean
I agree with not spraying water in the enginer compartment. I had a 1995 Integra GSR which I cleaned the engine before I sold it. I thought I was careful, the car started OK and ran well for 20-50 miles, then it started missing and losing power, I took it to the dealer, they said water got int he spark plug recess. They blew it out with air and everything was OK. The weird part is the car ran OK before showing the symptoms. There are also more and more electronics on cars today..water and electronic stuff don't mix.
Thanks for the tip!
I bought some of that Simple Green All purpose cleaner stuff from Wal-mart and sprayed it all over the engine compartment. After a few minutes, all the dirt just sort of disappeared! Almost no wiping! This is the best stuff I've ever used! I thought I would have to go through each nook and cranny with a toothbrush.
Now I'm gonna bust out the SG on my parents' I30.
Thanks very much for the tip, ya'll!
G
P.S. I don't know, but I think that stuff smells pretty good too.
G
Re: Thanks for the tip!
G
G
SidhuSaaB
05-30-2020 12:40 AM
joflewbyu2
10-08-2015 11:16 AM
STL TL-S
09-23-2015 08:52 PM
