Which direction to rotate crank
Hi All,
Getting reardy to do the timing belt on my 03 TL. Have couple questions:
1. Which direction do I rotate the crank to get the timing mark lined up? Clockwise or counterclockwise?
2. How do I best to about rotating it? At the crank pulley itself?
thanks,
anthony
thanks,
anthony
Always clockwise at the crank pulley bolt, there is an access hole in the right fender well.
If you rotate a little past your marks you can nudge it back a bit but if you get to far past it is best to just spin it around again.
RL.Devil (10-28-2022)
Just like he said. Remember, you do not need to line it up before you got the crank bolt removed. rotate it by the crank bolt. It is best to have the crank holding tool.
Also MAKE sure the cam mark lines up at the same time that the crank mark lines up.
Okay.... So use the 19mm socket to rotate the crank CLOCKWISE until the timing marks line up.
Then secure the crank with the crank holder tool, and break the crank BOLT free by turning it counter-clockwise right?
MAKE SURE the front cam mark is lined up where it should be when the crank mark is lined up. If not you are 180 off.
^^Sometimes you get a bolt that will fight you with everything it has. In that case, the crank pulley removal tool will be the one to give. I believe someone on the forum posted a pic of a broken removal tool.
acuratl26
04-23-2020 07:30 PM
xsilverhawkx
09-28-2015 06:51 PM
