Direct replacement blue LEDs for door light
Old 04-26-2002 | 03:20 PM
hchhon's Avatar
See the last two pics. As you can see you can directly replace your regular light bulbs in the side door and maplight.
http://www.thewebworks.com/nuke/modu...bum.php&page=2
Old 04-26-2002 | 03:44 PM
Nate's Avatar
These and these will also work, though probably not as bright. That one looks BIG! How does it fit in the door socket? I have the Autodynamic ones in my doors and I took a blue 1206 SMT LED off one of the circuit board wedge types and used it to replace the stock SMT LED in the ignition. Have you changed out that one yet hchhon? It takes a short 90 degree phillips to get out.
Old 04-26-2002 | 03:47 PM
hchhon's Avatar
Nate,
I had installed on my 2002 3.2TL already and it work! Very bright!
This LEDs cluster cost me about $25 each!
Old 04-26-2002 | 03:52 PM
hchhon's Avatar
Nate,
Here is side by side comparison of the orginal bulb from the side door and the blue LED cluster http://www.thewebworks.com/nuke/modu...bum.php&page=2
Old 04-26-2002 | 04:36 PM
hchhon's Avatar
Nate,
I have not change the light in the ignition key yet. Is it a blub or LED in here there? I will put a super blue LED in there soon. Is it hard to get it out?
Old 04-27-2002 | 08:41 AM
Nate's Avatar
Ahh, it was hard to tell the scale in the first pic.
Does it shoot a beam or is it pretty widespread? Got a pic of it in the door?
Ignition light is a surface mount LED. Its pretty easy to get out once you find all the screws. It will require a 90 degree angle phillips screwdriver as the steering wheel gets in the way of one of the screws.
Old 04-27-2002 | 11:37 AM
songoku's Avatar
BlingBling INSPIRE 32V
Stop playing with light bulbs.... j/k
Old 04-27-2002 | 05:26 PM
Seotaji's Avatar
where can i purchase white/superwhite LEDs?
the same 6 led pattern.
Old 04-29-2002 | 09:17 AM
hchhon's Avatar
Nate,
Here: http://www.thewebworks.com/nuke/modu...bum.php&page=2
Seotaji, I bought this from LEDtronics.com.
Old 04-29-2002 | 10:55 AM
TommyBoiSxty9's Avatar
hc - if one wanted you to convert their car to super white and red (like in the pics -- gauges and radio)
how much would ucharge?
Old 04-29-2002 | 01:02 PM
hchhon's Avatar
Tommy,
$200 for the CD/radio with ultra red LEDs or $280 with super blue LEDs.
I don't do the gauges because it is to hard and time consuming.
Old 04-29-2002 | 02:49 PM
Nate's Avatar
Thats hella bright but what I meant was how does it look installed in the door?
Old 04-29-2002 | 02:59 PM
hchhon's Avatar
Originally posted by hchhon
Tommy,
Nate,
I installed two of them in there (on each side of the door) by cutting off the base of the cluster LED and mounted two of them on one side of the PCB and mounted the the side of the PCB with the base that I cutted off. You got it? It fit perfectly! Very bright!
Old 04-29-2002 | 03:41 PM
Seotaji's Avatar
hchhon,
can you list the part number for that blue led bulb?
thanks
Old 04-29-2002 | 03:59 PM
hchhon's Avatar
Originally posted by Seotaji
hchhon,
thanks
Here you go: WF3126-0PB-014B
http://www.netdisty.net/ds/WF3126/
02-25-2020 10:57 AM
wusty23jd
09-24-2015 12:41 PM
drewdeezy03
09-03-2015 09:04 PM
pesobreeze
1G RL (1996-2004)
09-03-2015 01:26 PM
Quick Reply: Direct replacement blue LEDs for door light
