Dim Headlights? Replacement options?
Old Jan 7, 2008 | 08:57 PM
qwertybobo5's Avatar
Do the factory Xenon headlights get dimmer over time? Do they need to be replaced at any particular interval (i.e. before they actually go out completely)?
Mine seem to be dimmer than I remember them ever being. They are the original lights in my 2002 TL-S.
Should I replace them now? If so, do I use OEM parts or are there better aftermarket options?
Old Jan 7, 2008 | 09:02 PM
fsttyms1's Avatar
yes over time they loose their intensity. You should replace them in pairs. Contact our vendor Excelerate for good deals on HIDs.
I wrote up a DIY on how to replace them
https://acurazine.com/forums/showpos...89&postcount=2
Old Jan 7, 2008 | 09:06 PM
01tl4tl's Avatar
2000-3000 hours of use in general- or abour 5 years- Replace bulbs in pairs
Once they get dim with age its time- next you will see pink or purple tint when you turn them on- then one day, one dies and you scramble to order bilbs
Dealer gets 200 a piece for them
search threads for headlights and there are several opinions on Kelvin rating desired
Stock is 4300K- aftermarket 5000 and 6000 are white with blue tint.
I find those help me see better at night picking out lane markings and signs, and in rain recently, they picked out reflector dots in the road so I could navigate thru
Old Jan 8, 2008 | 02:15 PM
acitydweller's Avatar
the brightest light you'll get (in lumens) is the stock color 4500kelvin in D2R... if you want them slightly brighter, you can get D2S bulbs and modify the base to fit but that isnt recommended as you blind oncoming traffic.
Old Jan 19, 2008 | 08:10 PM
99TLhot's Avatar
yes oem light bulb does go bad, and if you have a TL that havent change the HID bulb, the color will be a bit of white dim purple. the OEM Bulb use D2R with the little sheal The D2S doent not have it,bulb that I use are 4300k very bright
Old Jan 19, 2008 | 08:13 PM
99TLhot's Avatar
and yea i use D2S with 4300k very very blind other people but who care LOL, and yea if you live in the place that snow D2S bulb it suck to drive in the snow tho.
Old Jan 19, 2008 | 08:19 PM
UA5 Crazy's Avatar
New Project 02 IS300
Check your pm box.
cycdaniel
Dec 17, 2019 10:58 AM
gemz_acura
4G TL Problems & Fixes
15
Sep 26, 2015 06:12 PM
eastcoastguy
Sep 24, 2015 02:07 PM
acuraST
Sep 17, 2015 02:31 AM
voigt
Sep 2, 2015 10:44 PM
