Differential fluid
Old Jun 13, 2002 | 03:05 PM
SwampGas's Avatar
/etc/car
Question Differential fluid
Just passing 22k miles...reading up and getting ready for the 30k DIY fixer-upper.
Flushing the coolant system and transmission seems easy enough...
However, what's the deal with this differential fluid? Can't find any info for it on the board, let alone how to change it.
If I remember from my R/C car, I think the differential is that thing which lets the drive wheels spin independently and lets the engine slip.
Old Jun 13, 2002 | 06:48 PM
RE: Tranny fuild changed not needed
I believe in the acura manual it say up to 60k and then every 30k after that but hey you could always replace with Mobil 1 synthtic ATF. It is suppose to give smoother shifts.
Old Jun 14, 2002 | 12:38 AM
mdaniel's Avatar
I thought FWD cars used a transaxle, single unit tranny and diff. So the same ATF circulates through both plus the torque converter.
Old Jun 14, 2002 | 12:43 AM
SwampGas's Avatar
/etc/car
mdaniel...you're probably right. I couldn't find any info on this, so I guess the ATF handles it all.
Old Jun 14, 2002 | 01:06 AM
Bitium's Avatar
Retired MOD
He is right....ATF (automatic transmission fluid) handles it all.
Old Jun 14, 2002 | 01:14 AM
Thumbs up
if you got rough shifts like i do from 1st to 2nd. I had my Timing belt replaced and fluid flushed. that hit da spot
Old Jun 17, 2002 | 06:42 PM
prlcivic's Avatar
first of all the diff is in the trans. second only use honda atf, otherwise you will end up with trans problems. you could go to 60 + miles, but with the trans problems that the tl's and cl's have already, why go that far. spend the money now on a simple atf change and hope that you wont have to pay for a trans later.
to the last guy who changed his t belt??? sounds like you have other probs besides the trans. t belt aint going to fix your trans problems
Old Jun 17, 2002 | 09:39 PM
Mobil 1 and Honda certified ATF additive is ok too
always use honda atf additive with any store bought tranny fluid
SidhuSaaB
May 30, 2020 12:40 AM
LeVeL
Oct 18, 2015 04:19 PM
hpfiend
Sep 27, 2015 06:59 AM
Cexarin
Sep 23, 2015 07:43 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
