D4 light blinking need help
Old Dec 12, 2008 | 08:14 PM
Sunsetdave770's Avatar
8th Gear
Driving down the road and spilled hot chocolate on the shifter and after starting the car 4 hours later the d4 light was blinking, is there an easy fix?
Old Dec 12, 2008 | 10:38 PM
Rajca's Avatar
wham bam thank you ma'am
take off the shifter cover and clean out what u can and see if that helps.
Old Dec 13, 2008 | 12:11 PM
01tl4tl's Avatar
CRC electrical contact cleaner in a spray can is your new best friend
shoot everything you can, remove the cup holder and go thru there too
and you may need to remove the center console to access the actual shifter micro-switches- there are 3 of them and moisture will kill one or more
Luckily they are only $35 each~, it just takes some time getting to them- its a plastic panel under the shifter, on the bottem side of that are the switches
mada51589
Jan 9, 2025 04:40 PM
Yikes
May 3, 2021 04:29 PM
BigJilm
Sep 21, 2015 08:32 PM
Ty-Sama
Sep 21, 2015 05:45 AM
whitesoxsfan12
Sep 13, 2015 02:09 PM
