cross drilling rotors
is it possible to cross drill your own rotors? will this pose a problem with rust or warping or anything. i just bought a set of brembo blanks because my stocks warped and i havent installed them yet. the cross drilled rotors are twice as expensive just for some wholes. any feed back appreciated.
Re: cross drilling rotors
I wouldn't recommend drilling the rotors yourself. It would make the rotor weaker structurally. Most cross drilled/dimpled/slotted rotors are also zinc coated to prevent rust. If anything, do what Bitium advice and dimpled/slotted them.
how would you go about dimpling/slotting them? just drill part way. as i said its no big deal as far as performance goes. from what ive read, for most driving slotted rotors make minimal difference. if it is easy to do without any adverse effects, it seems worth it to me. thanks for the quick replies
I wonder if drilled rotors have some kind of treatment to make them stronger prior to drilling, b/c drilling does weaken them. If that is the case, drilling a regular rotor may make it weaker/more prone to cracking than a real drilled rotor. Ask they people you got the rotor from if they know.
That's pretty ghetto IMHO. Incedentally drilled/slotetd rotors are only better when used in extreme situations. Normal street use you will not like them, although they do look nice.
Someone asked about strengthening? Cryo-freezing hardens them.
Originally posted by ExOwner
That's pretty ghetto IMHO. .... although they do look nice.
X-Drilled rotors look a lot nicer behind nice rims than stock rotors.
X-Drilled rotors aren't ghetto.
Ask the manufacturer before you buy. Mine can be turned.
Originally posted by 2002acuraTL
Dont forget also that you cannot 'turn' x-drilled rotors. If you get warping, you gotta toss 'em.
X-Drilling should be left to a CNC machine. You would never get the spacing as precise as a program could. You are asking for trouble if you try to do it yourself. Imagine a precisely weighed rotor and you randomly or systematically put holes. You effect the weight in different areas. A CNC machine is precise enough that after the X-Drilling is done you will have a balanced X-Drilled rotor where your attempt would throw off the weight balance.
Jul 16, 2017 07:33 AM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
blacktsxwagon
Oct 27, 2015 10:12 PM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
