cost of ball joints
I was asking cause i had the some problem about 3 months ago, it was covered by the warranty, i don't think it would cost that much, but if you take it to the dealership expect to pay a pretty penny
UB6IB9
1 million dollars Bwa-ha-ha-ha
Originally Posted by 1st timer
I just called,41cnd for lower and 144cnd for upper
Speaking of ball joints. Do the upper joints go bad as much as the lower? I was thinking about replacing them when I do my strut replacement. They look easy enough to replace.
OntarioTL
UB6IB9
Originally Posted by OntarioTL
Where did you get this quote, from the dealer? I got my lower for 50 Cdn at the dealer here in London.
OntarioTL
OntarioTL
UB6IB9
Originally Posted by TLofNYC
Do a search for my posts.....I had the work done and I listed the labor costs. I'm too lazy to search it right now.
The car is riding great now, i'm very happy with the service."
What part is the knucles and bearings?
Part # 1 is the knuckle
the bearing goes in the middle of the knuckle opening for the half shaft
The question is why would the replace that for teh ball joints
I just had my lower ball joint replaced (upper ball joints usually never go bad on our cars) by a local mechanic (not Acura dealer). Sometimes Acura pulls a scam and sells you a lower ball joint together with a knuckle, this is not necessary. You can buy a ball joint separately. In fact, you can get an after market lower ball joint for $30-40. There is no need to go with Honda ball-joint, I had a mechanic do mine for $140 labor plus $40 for a part, $190 total.
I am actually excited about trying non-Honda ball joint, because it is a 4th !!! time my car had a lower ball joint replaced. This is the first time I have non-Honda ball joint, I wonder if it will last longer. I think Honda ball joints suck big time.... well, time will tell..
I am definatly not going to the dealer anymore, they typically charge ~$500 to replace ball joint, any reputable shop will do it for half price or less.
Originally Posted by fsttyms1
Mine are still healthy at 200k so i dont consider them to suck
So far my after market ball joint works great....
Maybe on TL lower ball joints don't go bad as offten, but it seems to be a common problem (judging by number of posts) for 01-03 CLs. I personally had 1 lower ball joint replaced on passenger side, and this is my 3rd on driver side.
UB6IB9
I dont think its that common a problem. we really havent had that many members with issues. and the TL and CL share the same ones.
The ones I got are the AC Delco balljoints, are these any good?
Made in Korea.
Made in Korea.
My personal oppinion that those things tend to go bad more from time than miles. Also humidity and rain play some role... the ruber gets dry or something like that.
I also have non-Honda lower ball joint (not sure what brand), but it looks identical to the Honda ball joint on the other wheel, just slightly different color. It works great too.
how do they go bad??? like....takin rough turns??? or potholes...???
or wat
UB6IB9
Originally Posted by darshan_patel
not hijacking the thread!!....but
or wat
or wat
and the ride is alot smoother.
pot-holes more than anythig ,I replaced upper and lower(both wheir loose like crazy)
So how is your after market ball-joint, any difference with the Honda ?
Mine works great, and I am happy I saved lat least $200 by not going to the dealer...
when they go bad, you get anoying squaking sound when you turn your steering wheel (even while car is parked).
UB6IB9
Yes, pot-holes, bumpy roads....
mechanic charged me 50bucks for the install and i paid 220 bucks for all four balljoints,i saved about 300 bucks by not going to the stealership
so far i like them a big difference in the ride,alot smoother(cause of bad ball joints)
Did you also replace upper ball joints? Uppers usually never go bad.,
UB6IB9
All 4? I thought we only have two lower ball joints (left and right side fronty).
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
