Cooling system question
Old May 29, 2018 | 01:42 AM
Acuratl3535's Avatar
If I had air in my cooling system would my heater work? I took my thermostat out and replaced the coolant awhile ago and I don’t think I bled my cooling system. If there was air what would be some changes I would I notice. Can I just bleed it to be sure? What is the procedure to bleed it. I have a 2003 acaur tl. Thank you
Old May 29, 2018 | 07:34 AM
frankjnjr's Avatar
Use of the SEARCH FEATURE, regarding bleeding your cooling system, will provide you with the information you are looking for. Two symptoms, of low coolant level, and or, air in the system, would be, little or no heat, from the heater, and possibly, erratic engine idle. Properly bleeding the system, is easy, and will eliminate the aforementioned issues.
EllenCherry
May 27, 2014 11:45 AM
cmark
Console & Computer Gaming
Jun 26, 2006 08:38 PM
BuDDaHz TL
Jun 30, 2005 05:36 PM
Dan
Jun 13, 2003 01:15 PM
