Coolant Level Low
Old Mar 24, 2006 | 07:43 AM
1st timer's Avatar
UB6IB9
Coolant Level Low
Is it normal the my coolant level is low?(above low line but below max line).
I filled it up like 8 months ago.
Old Mar 24, 2006 | 08:25 AM
fsttyms1's Avatar
it should fluctuate in that container. Thats the overflow container and as the coolant gets warm or cold it goes into there as needed. If you notice that it starts to become empty and you have to keep filling it thats not normal
Old Mar 24, 2006 | 09:18 AM
1st timer's Avatar
UB6IB9
I don't notice any smoke when i start the car or while drive,blackstone however found traces of coolant when i did an oil analysis,they said it was a bit higher than normal.
Old Mar 24, 2006 | 09:25 AM
1st timer's Avatar
UB6IB9
The dealer won't even look at the car ,they say it's normal for the car to consume coolant.My level was at the full line about 8-9 months ago and now it's about 3/4 of an inch above the low line(while it's cold)How can i check to make sure i'm not burning coolant?
Old Mar 24, 2006 | 11:03 AM
fsttyms1's Avatar
Check it hot and running and see if its back to the top line. Like i said it WILL fluctuate. There is no real way of telling if your burning coolant with the small amount yours has moved in that 8-9 month time. Now if you were having to add that every week or day then you could say something was wrong.
08KBP_VA
Oct 22, 2019 01:55 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
ROSSARONIE
Oct 2, 2015 11:46 AM
Username 0
2G TSX Performance Parts & Modifications
23
Sep 28, 2015 09:09 AM
Rcelestino93
Sep 23, 2015 10:01 PM
