Coolant Flush
Old Dec 7, 2006 | 02:02 AM
harminder247's Avatar
:( Harminder Is Lost In
Coolant Flush
hey guys im about to hit 100k and was wonder what kind of coolant should i use and should i use all coolant or should i mix it with water?
Old Dec 7, 2006 | 03:06 AM
desired_speeds's Avatar
you cannot use all coolant. they recommend 50/50 for coolant and water. I suggest that when you flush the coolant, to run Ford coolant flush through it and take your time with it. I also suggest using OEM Honda coolant
Old Dec 7, 2006 | 08:08 AM
fla-tls's Avatar
On the way!
If you use OEM coolant - which I would recommend (it's about the same price as any other brand - and made for your car), then DO NOT mix it with water as it is already premixed 50/50.
Just read the label - it's pretty obvious.
Old Dec 7, 2006 | 10:00 AM
fsttyms1's Avatar
Stick with the oem coolant. ITs about the same price as teh others and its already premixed
Old Dec 7, 2006 | 10:33 AM
ok thanks guys and one more thing, how much is needed? would just one fill it up or no?
Old Dec 7, 2006 | 11:06 AM
acurabum's Avatar
Completly flush 1gallon and a half .. if you only drain from the bottom of the radiator then
only 1 gallon .....
Old Dec 7, 2006 | 05:35 PM
how can i get it ALL out?
Old Dec 7, 2006 | 07:21 PM
fsttyms1's Avatar
removing the lower hose and the plug on the back of the block
Old Dec 7, 2006 | 10:40 PM
thanks
Old Dec 8, 2006 | 12:03 PM
acurabum's Avatar
Steps to follow are in your owner's manual if you still have one ......
adrian_s2k
1G RDX (2007-2012)
23
Jan 12, 2016 04:25 PM
ROSSARONIE
Oct 2, 2015 11:46 AM
hashbrown
Sep 29, 2015 12:13 PM
Username 0
2G TSX Performance Parts & Modifications
23
Sep 28, 2015 09:09 AM
Ratheruneeq
Sep 28, 2015 07:41 AM
