Comptech Quiet tip insert
Old Nov 4, 2002 | 09:17 AM
Does anybody have the Comptech Quiet tip insert? If so how much of the noise is cut down.
Alan
Old Nov 4, 2002 | 10:01 AM
NSXNEXT's Avatar
I have em. They make the car sound just like stock at crusing speed. It totally gets rid of the 2500 - 3000 rpm droning noise. I highly recommend them.
Best part is you can pop them out in 2 minutes if you want it a bit louder.
Old Nov 4, 2002 | 08:01 PM
SilverUA5's Avatar
I assume those things are for Comptech exhaust and not stock right?
Old Nov 5, 2002 | 08:03 AM
NSXNEXT's Avatar
Correct.
Old Nov 5, 2002 | 05:40 PM
iliveinapathy's Avatar
they dont drown out to the point where it sounds stock really... plus i remember someone saying they lost 2 whp when they dynoed with inserts in....
something to think about
Old Nov 5, 2002 | 05:53 PM
fsttyms1's Avatar
you would never notice 2 hp even if that was true
Old Nov 6, 2002 | 09:02 PM
I may have to invest in these.
Old Nov 6, 2002 | 09:17 PM
Raheel's Avatar
Old Nov 6, 2002 | 09:21 PM
AggieTL's Avatar
Quiet tip inserts make taking the car on a trip at regular cruising speeds much more tolerable....without them the drone started to give me a headache.
Old Nov 8, 2002 | 12:09 AM
Definately, I got tired of the drone from the Comptech after a while and got these. Car sounds perfect now.
Old Nov 8, 2002 | 11:37 AM
Nitin's Avatar
But I just got here
How'd you guys install the quiet tip inserts? Do you just need a screwdriver and stick them in there?
Old Nov 8, 2002 | 12:03 PM
NSXNEXT's Avatar
You need to drill a hole into the inside of the exhaust tip. They come with instructions and a bit.
Old Nov 8, 2002 | 01:45 PM
An automatic center punch will definately help as well.
Old Nov 8, 2002 | 03:09 PM
FTM-1's Avatar
PhiTL & QUIETSTORMMVN_IN good to see you boys on here again. I missed you guys being at the PARK AVE TL/CL meet this summer.
Old Nov 8, 2002 | 10:51 PM
I've been here off and on but not posting much. Good to see ya.
Old Nov 9, 2002 | 06:04 PM
fuggedaboutid's Avatar
I have an Accord V6, has a 3.0L V6 (J30A) vs. your TLs 3.2L (J32A)... I have Axle back exhausts - Bosal Brospeed. Everything is satisfactory about it. I just wonder why there is a mild drone at 2000-3000rpms in overdrive (D4)? It's more noticeable when it's really cold out regardless of engine temp. Also, it's bad on a Hot summer day as well. Any suggestions please?
Jul 16, 2017 07:33 AM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
CL-S progression 01
Jan 26, 2016 04:15 PM
ivan06106
Sep 26, 2015 04:38 PM
