Comptech Icebox doesn't fit?
Old Nov 17, 2003 | 10:55 AM
I installed my icebox on saturday but i had to leave it loose cause my front driver side Headlignt harness prevents me from installing it all the way. Has anyone else had this problem and if so let me know how and if u fixed it? I have a regular TL not a type S.
Old Nov 17, 2003 | 11:18 AM
Twenty03 Type-S's Avatar
From my understanding you have to do some type of cutting/trimming. Try a search on this, I've read about this on the boards...
Old Nov 17, 2003 | 01:47 PM
kent_99TL's Avatar
Correct, you have to cut the opening a little bit bigger on the cover to make it fits.
Old Nov 17, 2003 | 01:58 PM
on the icebox or on the headlight?
Old Nov 18, 2003 | 10:47 PM
Allout's Avatar
Blown is Best
I've got a 99 and Comptech had to grind open the upper box so it fit around the HID cover. I took mine to Comptech so they could use it to make the template.
Call Comptech and they will probably send you one that is already ground open to fit. They have to modify the upper lid for the 1999 - 2000 TL-P.
Old Nov 18, 2003 | 10:49 PM
Ill do that....thanks
BoricuaTL
Apr 8, 2016 01:08 PM
Nitin
Sep 30, 2015 08:22 PM
k6biv
Sep 22, 2015 02:06 PM
TSX 09
Sep 14, 2015 10:25 AM
Leester01
Sep 11, 2015 06:35 PM
