Compression question...
Old Mar 12, 2003 | 11:55 AM
Darkshear's Avatar
l33t
Question Compression question...
I have a '99 TL. I know the basic in and out of a motor, but im curious how hard it would be to get my compression up to TL-S spec. Is it even possible or am i just stupid?
Old Mar 12, 2003 | 12:30 PM
Tom Blasing's Avatar
is the Mighty Favog
For one the crank shaft would/should have to be replaced because the connecting rod journals are more offset from center. With that I don't think the connecting rods would need replacing. Also, it would be a good idea to check valve clearance o fthe pistons.
This all assuming there isn't any other differences in the parts fitting.
Old Mar 12, 2003 | 12:37 PM
Ray_Khan's Avatar
it's probably not as cost effective as selling your car and getting a used TLS. And that way, you can get a warrantied car with other TLS features.
Old Mar 12, 2003 | 07:45 PM
ChucksCL-S's Avatar
You could lower the heads closer to the block with shaving or a really thin gasket but your ECU might not be able to handle the possible knock, it may pull back timing, or it might work great, I don't know. I'd do AEM CAI first and headers which is roughly 6 plus 16 HP at the wheels.
Old Mar 12, 2003 | 07:50 PM
Darkshear's Avatar
l33t
i plan to do headers and exaust, i already have intake, but i know ill always strive for more
1fatcrxnem1
22
Jun 1, 2018 01:23 AM
mossman77
1/2G MDX (2001-2013)
18
Sep 16, 2015 12:21 PM
Sep 13, 2015 01:59 PM
