complete engine tune-up
Old Jul 1, 2005 | 11:21 PM
@cUr@-TL's Avatar
'99 Acura 3.2TL
hey guys im gonna get my timing belt replaced soon so i thought i might as well do a complete tune-up so i'd like to know what parts would need to be checked/replaced, etc... I want it to run like new.
my list:
all the filters
all oils
cleaning the intake/manifold
spark plugs
injector cleaner
thanks
-justin
Old Jul 1, 2005 | 11:30 PM
aaronnn's Avatar
might as well get a huge carb cleaner can and do the EGR cleaning so you wont have to do it later on when the check engine light comes on.. its common among the TL's.
Old Jul 2, 2005 | 09:22 AM
NickB's Avatar
Life changes by the day
If your changing your timming belt, it's a good idea to change the waterpump at the sametime while it's all apart.
Old Jul 2, 2005 | 10:01 AM
1st timer's Avatar
UB6IB9
my list:
all the filters
all oils
spark plugs
injector cleaner
thanks
-justin
i guess you're including fuel filter when you said "all filters"?
Old Jul 2, 2005 | 11:52 AM
@cUr@-TL's Avatar
'99 Acura 3.2TL
yes.
so, anything else i should look for??
Old Jul 2, 2005 | 12:22 PM
JimmyTLS's Avatar
Throttle body cleaning, if you have high mileage, might as well get a valve adjustment (may not need one but might as well), change valve cover gasket, coolant flush, trans flush, brake fluid. Thats all I can think of on top of what was already mentioned.
Old Jul 2, 2005 | 04:23 PM
Tyzing's Avatar
can new spark plugs even be measured as far as HP goes, if you get some titanium plugs or something? 1-3hp gains?
Old Jul 2, 2005 | 07:26 PM
sbuswell's Avatar
I need 2 more gears
sparks plugs equal no gain! Iridium's last longer. NGK Iridium IX plugs last 100k while Denso iridiums are supposedly 30k but I believe much lkonger life can be expected. Check your coils packs and might as well get a cylinder pressure check and battery check also. How about new 02 sensors. Man a complete tune-up on a TL is like replacing as parts that fail over time after wear and tear. How many miles do you have and just stick to the owners manual(other than cleaning IM&TB, that's just a great idea).
Old Jul 2, 2005 | 08:02 PM
Da_iLLeZt_TL973's Avatar
Future JDM Whore
my list:
all the filters
all oils
spark plugs
injector cleaner
thanks
-justin
not trying to highjack thread but i might be getting this done also so how much do you guys think this will cost??
Old Jul 2, 2005 | 09:11 PM
NYCdesiPola's Avatar
how you guys do the Valve adjustment & valve cover change ? l have 99TL got 170,000 problem with stearing it lil vibrate...
Old Jul 2, 2005 | 09:32 PM
timmy8151's Avatar
Save yourself a lot of money and do most of the work yourself. Except for the TB, all of these tasks can be done at home. Get yourself a Helms service manual, a set of hand tools and go for it.
Not only will you save loads of money, you'll get the satisfaction of working on your own car.
wusty23jd
Sep 24, 2015 11:41 AM
JarrettLauderdale
2G CL Dynograph Gallery
Sep 21, 2015 07:51 PM
Sep 15, 2015 06:44 PM
Sep 14, 2015 10:09 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
