Cold transmission shifting and Sport mode ?
Weird shifting issue that just "popped" up overnight .... hard/delayed upshifting and downshifting when the car/transmission is cold ... after about 15 mins of driving, it resolves and shifts normally.
ALSO associated: when cold, the "Sport Mode" shifting will not work, no digital gear counter, no ability to upshift or downshift ... NOTHING .... then around the same time the COLD shifting problem resolves, the "Sport Mode" begins to work.
Has anyone seen this or have any ideas ? Is there any thermal sensor or feedback loop to the transmission ECU that might explain this ?
Thanks for any help !
The following 3 users liked this post by whitetiger5:
Interesting,.. 14F ... but my experience has been just chilly mornings .... maybe in the 40s or 30s .... But it has been predictable, and repeatable .... makes me wonder how it works, could I have a faulty sensor ?
The car is a 99, with the 4 spd .... 208K thousand miles ..... had the transmission rebuilt at approx 170K
Thanks for the reply.
I think so ....definitely seems like a sensor could do this .... it was fine one day then the next it was not. Its not especially cold here .... GA in the springtime ... rarely gets below freezing. It did briefly show the TCS light, so that's transmission or ABS right ? .... it only light up once.
Thanks for the reply ... I'm going to try cleaning out the solenoids. I had this tranny (99 TL 4 spd) rebuilt two years ago, but I'm thinking maybe the shop did not do anything with the solenoids.
Well it been a while since I posted about this .... if anyone is interested here is what I did and learned .... Since it was obviously a temperature thing (transmission behaved normally after warm-up) ... checked the ECT (engine coolant temp sensor) ..... found it broken... literally snapped. replaced it and xmsn shifting problem instantly solved. The ECT send temp signals to the ECM .... the ECM also controls the transmission .... the ECT signal into the ECM was probably way off at startup .... bad data (garbage in garbage out) thing. Also learned something else interesting about this sensor on Honda J series engines (probably others) The sensor screws into the engine coolant system at a point where air pockets tend to form if your system is not properly purged of air. In very hot conditions the ECT can be reading the temperature of basically superheated air(steam) inside the coolant manifold. if that happens then again its garbage in garbage out. I read many posts regarding hard restarts when the engine was hot having sat for a short time ... sometimes refered to as "vapor lock" .... Anyway we had that happen several times summer of 2021 & 2022 .... I purged all the air out of the coolant system and it has not happened again.
Hope this helps someone.
The following 2 users liked this post by jkpiitch:
Florida Wen (11-12-2023),
whitetiger5 (11-13-2023)
MattViperTLX
04-26-2018 09:00 AM
quintno
5G TLX Problems & Fixes
04-13-2015 08:13 PM
