Cold air intake
Old May 7, 2014 | 07:26 AM
mcottrell95's Avatar
Cold air intake
I was looking into gettinf a CAI for my 2nd gen tl non type s. Any reccomendations? Ive been hearinf that it doesnt even matter what you get, and you can even make your own.
also would one made for the type s fit the stock tl? Or is it diferent?
Old May 7, 2014 | 09:47 AM
BoriTL's Avatar
I went with an Ebay intake $40 cant go wrong, just change the filter to a K&N
Old May 7, 2014 | 01:02 PM
Skirmich's Avatar
Type-S has a 2nd Throttle body for the VSA Traction control system so the pipe is shorter and it won't reach the TB of the TL-p.
Your best bet is the AEM v2 CAI if your not planning in upgrade to a bigger TB in the future or a TL-S Swap.
Old May 7, 2014 | 03:22 PM
The one im looking at looks identical to the regular one. But says for tls. Is it noticeably shorter?
Old May 7, 2014 | 03:26 PM
http://www.amazon.com/gp/aw/d/B003ZH...440_em_1p_2_ti
Thats the intake i was looking at
Old May 7, 2014 | 05:55 PM
Skirmich's Avatar
^ It says TL (Not TL Type-S Anywhere)
CL Type-S 6 Speed Doesnt have VSA so it will fit the CL Type-S 6 Speedo but not the Automatic CL Type-S which again has VSA...
So it will fit your TL-p nicely if its made for the CL Type S Manual (NOT AUTO).
To Sum Up:
TL-p (Same Throttle Body)
CL-p (Same Throttle Body)
CL-S 6 Speed (Slightly Bigger Throttle Body)
^ Can use same CAI, CL-S 6 Speed will have a slightly bigger tube diameter but it will fit the smaller TBs OK regardless.
TL-S (VSA)
CL-S AUTO (VSA)
^ Needs Shorter CAI.
Old May 7, 2014 | 06:10 PM
HairyMonkey019's Avatar
Isn't there a way to delete the VSA? I remember reading it in the past, and Would actually want to do this now.
Old May 7, 2014 | 06:25 PM
Skirmich's Avatar
^ Unless you go for FULL Performance (Swap to Manual ECU to avoid MIL Codes) and get a bigger TB there is hardly any reason to mess with the VSA TB it doesn't change the gains from a CAI for Example and if it does it would be so slightly that it will not out weight the cons (Like Losing Traction Control).
AUTOs need it for the traction control and it will pop codes if you disconnect it so I cant see how can you delete it without messing with the AUTO ECU.
Old May 8, 2014 | 08:20 AM
Thanks man. That makes alot of sense. Greatly apreciated. Ill make sure to post some pics after i do it!
tsx_boy
Dec 13, 2019 08:33 PM
Jul 16, 2017 07:33 AM
rcs86
Aug 2, 2016 06:52 PM
hashbrown
Sep 29, 2015 12:13 PM
