Code P0122
Old Sep 2, 2008 | 05:38 PM
170155's Avatar
Unhappy Code P0122
Hello everyone...
My wife was driving home when the Engine & TCS lights came on.
The car started shifting funny but she made it home...
The code I recovered was P0122 Throttle Position Circuit Low Input.
I erased the code but the car "jumps" a bit when going from R to D
but not N to D or from P to R.
Could this jump be linked to the TPS?
Aside from just replacing the sensor, can it be tested?
Any help, as always, is appreciated.
Old Sep 2, 2008 | 10:34 PM
170155's Avatar
Anyone?
I have done some research on this site about the TPS being part of the throttle body but does anyone think it could attribute to the little jump
felt going into D?
Old Sep 2, 2008 | 10:57 PM
bowlgers's Avatar
268hp 301tq @7.8psi
get another throttle body tps is part of it try a bone yard or ebay dealers about 250 range depending were u live
Old Sep 2, 2008 | 11:02 PM
6MTUA5's Avatar
No He Can't
It is a sensor on the front side of the TB
Old Sep 2, 2008 | 11:08 PM
6MTUA5's Avatar
No He Can't
EDIT: That smiley is supposed to be WERD
Bolt 15 goes right by it
Old Sep 2, 2008 | 11:10 PM
6MTUA5's Avatar
No He Can't
Car-part.com searches online junkyards. You can find the TBs on there for pretty cheap. I need to get one b/c my IACV is FUBAR and my TPS got ripped off by the chain when we were pulling my motor for the swap.
Old Sep 2, 2008 | 11:39 PM
170155's Avatar
I was deciding if I should get new or not...also, the way the car jumps when going into D, it feels like a trans issue and with the TL's history of trans issues...I'm not hopeful that all it is will be this TPS....any words of encouragment?
Old Sep 2, 2008 | 11:52 PM
6MTUA5's Avatar
No He Can't
That's the thing it's kind of built into the TB
Old Sep 3, 2008 | 09:29 AM
fsttyms1's Avatar
Others have had the TPS sensor cause the jump your feeling.
Old Sep 3, 2008 | 09:30 AM
fsttyms1's Avatar
Should have pulled it this way...... IM off
Old Sep 3, 2008 | 10:22 AM
170155's Avatar
So would you
A: Buy a new one at $400
B: Buy a salvage one at $100 but have a giant ? on life expectancy or if it even works
C: Test drive one from an Acura dealer and do the old switch-a-roo
Old Sep 3, 2008 | 12:02 PM
fsttyms1's Avatar
Buy a used one. They arent a common issue here.
Old Sep 3, 2008 | 05:38 PM
6MTUA5's Avatar
No He Can't
Always have to 1up me, don't you?
Find a used one
Old Sep 3, 2008 | 05:56 PM
fsttyms1's Avatar
Find a used one
Like my Vtec works
Old Sep 3, 2008 | 05:57 PM
170155's Avatar
I went with a used one. The salvage yard extends a 30 day warranty, enough to
know if it is dead right now. It looks like 4 bolts and a gasket....does that sound right?
I ordered both gaskets from Autozone, not knowing which is the one I will need.
I just need to clean the salvage throttle body out....carb cleaner or MAF cleaner?
Old Sep 3, 2008 | 08:08 PM
fsttyms1's Avatar
yep pretty easy to change. Get a carb cleaner and a old tooth brush and clean things up. Take the IACv off and clean that out while you at it.
Old Sep 3, 2008 | 09:17 PM
6MTUA5's Avatar
No He Can't
Like my Vtec works
It's probably good that I'm running in limp b/c I need to get my valves adjusted. I'm just going to keep telling myself that.
Old Sep 4, 2008 | 01:56 PM
170155's Avatar
Well, 2 bolts, 2 nuts, 4 disconnected hoses and one disconnected main intake later...I have the salvage yard unit on. Everything reconnected, battery cable in place and I start the engine. Starts fine but then the engine revs to 3k RPM and stays there so I goose the throttle and that starts a hunting idle from 1k to 3k RPM.
ideas?
Old Sep 4, 2008 | 02:00 PM
Gfaze's Avatar
S E L L
ideas?
Bad TB most likely. CEL on?
Old Sep 4, 2008 | 02:01 PM
170155's Avatar
Nope, no codes but the engine is cold and I am running it long enough to get warm.
Partly because I don't like working on a hot engine and because I don't want to make things worse.
Old Sep 4, 2008 | 02:07 PM
6MTUA5's Avatar
No He Can't
Sounds like the IACV getting stuck. Did you take it off and clean it before you installed the TB?
Old Sep 4, 2008 | 02:08 PM
yunginTL's Avatar
trill recognize trill
i just ordered mine today i had the same problem i thought it was the tranny at first
Old Sep 4, 2008 | 02:17 PM
170155's Avatar
6MTUA5---No I didn't take the IACV off...which sensor is that? The one on the bottom?
with the torque screws? Is it a trick putting it back? like only a special way?
Old Sep 4, 2008 | 02:42 PM
fsttyms1's Avatar
Iac is on the bottom. You must have a 99? Cause every TL ive seen had philips screws. Take it off and clean it with carb cleaner. Care full not to ruin the rubber gasket (can reuse it)
fsttyms1's Avatar
Keep telling yourself that
Old Sep 4, 2008 | 02:44 PM
6MTUA5's Avatar
No He Can't
Yea the 99 does have a star pattern IIRC. I found this out by sitting there forever with a stubby Phillips head and just could get it. Finally I took the whole TB off and saw that they were different.
Old Sep 4, 2008 | 03:44 PM
170155's Avatar
I was wrong, the $#@! screws are not torque or hex or anything else...the PTB used a 5 pointed star shaped screw....just great.
I went to Lowes, Home Depot, Pep Boys and Autozone...no one has a 5 pt star tool
Time to drill them out, any last words?
Old Sep 4, 2008 | 03:59 PM
fsttyms1's Avatar
What a PITA.....
170155 can you get a philips or a torx or a flat head to fit in there just to make it work? Once removed take the screws to a hardware store and get ones that are philips or something easier to install and remove.
170155's Avatar
The bottom sensor has a total of 4 screws. 2 philips and 2 bitch kind.
The philips ones remove the while thing while the bitch ones, now that I have them
drilled off, reveal a magnet of sorts on a spindle.
Where do I clean it?
Old Sep 4, 2008 | 04:03 PM
fsttyms1's Avatar
that piece is suppose to move to allow air to flow. Clean all the way around it. get all carbon and parts dirty clean
Old Sep 4, 2008 | 04:11 PM
170155's Avatar
doing it now...
Old Sep 4, 2008 | 04:36 PM
170155's Avatar
ok, the salvage yard one is 80% sticky trying to turn, my old one was 15% sticky turning
so I will use my old one...I'm off to Lowes for some screws...
$#@! 5 pt star screws...ughfm shitinrattin fricken ....rrr
Old Sep 4, 2008 | 05:58 PM
170155's Avatar
All done.....
I love you guy!
It is fixed, no more code, no more jumping and my trans with 190k is still going strong....
(finding some wood to knock on...)
This site rocks .... better than the dealership, couldn't get any advice or help from them.
Old Jul 31, 2013 | 07:00 PM
reaper101's Avatar
live fast or die slow
does anyone know what the part is called i got this code and my car has been jerking for a while but im just guessing its the trans but this code popped up the other day when i was pushing the car rough and i cleared it and it stayed away for a while but now pops up everytime i turn my car on after being cleared so im sure i need to replace that part
tks
Old Aug 1, 2013 | 07:57 AM
3.2TLc's Avatar
Throttle Position Sensor is what they were working on.
A P0112 code could also be low voltage within the IAT sensor's circuit. Check wiring and connectors, clear code and recheck if it comes back.
Jamus22
Jun 11, 2023 10:08 AM
MilanoRedDashR
Oct 2, 2015 10:49 AM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
mars
Sep 28, 2015 11:03 AM
