Clunking sound
Old Dec 29, 2005 | 02:34 PM
kuzdu's Avatar
Styl1n
Clunking sound
When my car is stopped and i step on the gas and let go the car moves and i hear a clunking sound from the front of the car
any idea what it might be?
it doesn't affect the way the car drives?
Old Dec 29, 2005 | 02:36 PM
mdavisii's Avatar
B93P TL Owner
Engine mount maybe?
Old Dec 29, 2005 | 02:51 PM
phipark's Avatar
Not Asian
When you step on the gas can you feel something shift then the car starts to go? If so, that's a motor mount.
Old Dec 29, 2005 | 02:57 PM
aw1's Avatar
aw1
could be ABS
Old Dec 29, 2005 | 03:43 PM
lindros2's Avatar
Black
could be brakes - my [aftermarket] pads made a clunking noise because they weren't an absolute exact fit - fairly common and didn't affect anything other than an annoying sound
Old Dec 29, 2005 | 05:52 PM
loud_whispers's Avatar
Talking
could be aftermarket pads..
could be engine mount..
definitely not anything to do with the ABS system whatsover..
-check front engine mount..clunks..
-check brake pads, aftermarket or non-greased pads will move in the caliper holders and cause a clunk.
-swaybar endlinks and bushings, also check to see if the swaybar itself is actually -moving in and out of the bushings.. that will cause a clunk..
-check axel nuts, they must be very tight and staked to the axel..clunks
-if you've had the transmission done on your car, then check the front passanger side radius rod bushing, may be backwards or not tightened at all. will clunk..
-check power steering rack bolts..they must be tight. will clunk if the rack isnt secure
-check lower ball joints for excessive play..will clunk if the joint is dry
-check all subframe bolts. will clunk..
now you get an idea of what tech's go through everytime we get a customer with a "clunk" from the front end written on the work order!
Old Dec 29, 2005 | 08:35 PM
kuzdu's Avatar
Styl1n
yeah it's a lot so i guess i will take it into Acura on Monday......it's only when the car is stopped then you step on the gas and let go....you here a clunck sound...
Hopefully Acura can find it
Old Dec 29, 2005 | 08:49 PM
bkzjimmy's Avatar
NiGhT rIdEr
i had that same problem.....i had 2 bad motor mounts. (right and front)
Old Jan 2, 2006 | 01:54 PM
kuzdu's Avatar
Styl1n
I took it to the dealer and it was a bad front motor mount
mlody
Dec 4, 2019 02:11 PM
DerrickW
Nov 15, 2015 05:52 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
hashbrown
Sep 29, 2015 12:13 PM
Brandle34
Sep 23, 2015 07:20 PM
