Clunk Noise when starting the engine
Anyone knows of this problem - when starting the car I can hear a clunking noise right behind the engine on the bottom. The clunking noise is consistent everytime the car is started. Could this be the rear engine mount is bad? The clunking noise sounds like metal contact hitting one another. Thanks
Originally Posted by bkzjimmy
thats what i heard when my mounts were broken.
if you do a search for motor mounts you should find all the info you can handle!!
Originally Posted by 03CoupeV6
Not so sure about that. I had my engine mounts replaced and my "clunk" persists. But mine is ONLY when the car is cold. You car does this every time?
rockyboy
08-04-2024 10:35 AM
Mike Bertram
09-10-2015 09:27 AM
