Cleaning throttle???
Old Nov 7, 2007 | 12:34 PM
myTaLizaS3.2's Avatar
So lately, I've noticed that my throttle seems like it's a little stuck. When barely steping on the gas, it won't go, but If I apply a bit more pressure, it'll then move. This happened with my old integra, and I cleaned the area where the flap closes and it was fine then. Can I do the same? Or what should I use to clean and how? Thanks.
Old Nov 7, 2007 | 12:40 PM
phee's Avatar
I got the Shifts
yea man, all you have to do is remove the intake from the throttle body and spray it down with THROTTLE BODY cleaner, DO no use carburetor cleaners, thats way too harsh. be generous in the amount you use and wipe down the butterfly flap with a towel to get all the gunk out, and you can push a lint free cloth into the Intake Manifold to remove the Excess cleaner. then put everything back together and hold the gas pedal down as you start it so you can burn all the cleaner away. dont be afraid if it doesnt start correctly the first time, just keep pumping it. pm me if you need help, i did this last week and it made a BIG difference
Old Nov 7, 2007 | 12:42 PM
01tl4tl's Avatar
some use carb cleaner- I prefer the specially designated Throttle Body Cleaner, same price- supposed to be safer around plastic
Engine off- remove whatever intake system- open throttle by hand at lever
Spray per directions- 3-5 seconds- close valve- spray again- open, spray, some crud should run out- wipe up what you can.
Reassemble and start engine, may run bad a few minutes- like when seafoamed
Pull fuse #8 clock backup fuse and reinsert- that resets the ECU
Try some seafoam in the tank and intake vac line.
Remove throttle cables- spray wd or silicone spray inside and work cable back and forth,
reassemble
test drive
Old Nov 7, 2007 | 12:49 PM
phee's Avatar
I got the Shifts
OH MAN, thanks for telling me how to reset my ECu, for some reason my shift points got all off after i did this, my car stays in 3rd gear all the way to 50mph in auto, its fun hearing it rev but i was used to it when it would be in 4th by 20MPH
Old Nov 7, 2007 | 12:52 PM
thanks phee and 01tl
Old Nov 7, 2007 | 01:00 PM
phee's Avatar
I got the Shifts
no prob
Old Nov 7, 2007 | 01:14 PM
fsttyms1's Avatar
Seafoam and a tooth brush work as well.
Old Nov 7, 2007 | 02:00 PM
01tl4tl's Avatar
the manual method- I hadnt even thought of using seafoam that way- clever fsttyms!
Old Nov 7, 2007 | 03:19 PM
fsttyms1's Avatar
Works very well on teh EGR ports and the tracks in the upper plenum as well.
Old Nov 7, 2007 | 04:05 PM
01tl4tl's Avatar
And I was going to use the solvent tank and be all cool and hi-tech about cleaning the intake manifold/EGR- just like in the acura bulletin.
then...the buffing wheel.
Someone beat me to posting on it but they are gen3 I believe
- seafoam and a toothbrush and I thought I was old school-
I guess I am just old
Old Nov 7, 2007 | 04:53 PM
fsttyms1's Avatar
Thats ok. We understand
Old Nov 8, 2007 | 08:59 AM
acitydweller's Avatar
Actually i'd like to add using a plastic pinch or clothes pin to let the seafoam slowly drip into the intake manifold. The results under this application are noticibly better than simply letting the vacuum line slurp up the seafoam fluid.
Old Nov 8, 2007 | 09:01 AM
fsttyms1's Avatar
its best if you can pour it into a old spray bottle and spray it into the TB while the car is running. Vac lines get none on the TB area. Its still recommended to let a vac line suck in a whole can. More of it will get to teh valves. Hand cleaning is still the best method.
Old Nov 8, 2007 | 10:03 AM
01tl4tl's Avatar
threadjack-
read the thread "seafoamed the ol TL" for proper directions of dip and remove dip and remove vac line from can while using thumb to raise throttle
Smoke should be coming out the exhaust when the can is about empty- thats a job well done- wait 5 minutes and drive it hard
hashbrown
Feb 18, 2022 11:20 AM
08KBP_VA
Oct 22, 2019 01:55 PM
Jul 16, 2017 07:33 AM
Username 0
2G TSX Performance Parts & Modifications
23
Sep 28, 2015 09:09 AM
