Check Engine Light Reset?
Old Feb 26, 2007 | 03:36 PM
Beantown's Avatar
6th Gear
Is there anyway I can reset the check engine light on a 1999 Acura 3.2TL w/o bringing it to a garage? I know what the problem is but don't have enough $ to get it fixed at the moment.
Any help wouldbe great.
Old Feb 26, 2007 | 03:57 PM
t7n7's Avatar
Wish
u need a device that connects to the OBDII system... sorry i know many but i don't know which is the cheapest so hopefully someone else here can get u a cheap product to do that.. it connects to ur car and tells u wat the error codes are as well as having the ability to reset it
Old Feb 26, 2007 | 04:01 PM
Hot Boi's Avatar
Grippin' Grain
There are two fuses in the passenger side fuse box that u can pull out and put back in and it should go off. I forget which #'s they are though. Kris could tell you which ones to pull.
Old Feb 26, 2007 | 04:05 PM
fsttyms1's Avatar
Well if there is a problem the light will come back on. There are 2 ways of resetting it. EIther disconnect the battery for like 10 min or you can pull the clock backup fuse on the passenger side dash fuse panel
Old Feb 26, 2007 | 04:46 PM
t7n7's Avatar
Wish
welll well well.. learned something new myself
MikeYutkin
Sep 10, 2015 10:13 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
