Check Engine Light Reset?
Is there anyway I can reset the check engine light on a 1999 Acura 3.2TL w/o bringing it to a garage? I know what the problem is but don't have enough $ to get it fixed at the moment.
Any help wouldbe great.
Wish
u need a device that connects to the OBDII system... sorry i know many but i don't know which is the cheapest so hopefully someone else here can get u a cheap product to do that.. it connects to ur car and tells u wat the error codes are as well as having the ability to reset it
Grippin' Grain
There are two fuses in the passenger side fuse box that u can pull out and put back in and it should go off. I forget which #'s they are though. Kris could tell you which ones to pull.
Well if there is a problem the light will come back on. There are 2 ways of resetting it. EIther disconnect the battery for like 10 min or you can pull the clock backup fuse on the passenger side dash fuse panel
HeloDown
09-08-2015 06:51 PM
