Check Engine on at 6000miles
Old Oct 30, 2002 | 07:16 PM
hgiljr's Avatar
Is this normal? It blinks a couple of times when I start the car and then goes away. Is this just informing me to do my oil change at 7500 miles? Any help appreciated. Thanks Hector
Old Oct 30, 2002 | 07:17 PM
Yes that is it... reseting instructions are in the manual
Old Oct 30, 2002 | 08:11 PM
drcookie's Avatar
Re: Check Engine on at 6000miles
Yup ! That is normal. It means it's service time and the Dealer wants your money !!!!
Cheers !!!
Old Oct 30, 2002 | 11:15 PM
SHould I got o dealer at 7500 miles for oil change or shoud I just do the oil change myself. Either way I will supply Mobil 1 5w-30 to the dealer. I hope they don't have a problem with this.
Old Oct 30, 2002 | 11:30 PM
snapple's Avatar
Yup normal as can be. The dealer will reset it after your 7500 mail service
Old Oct 31, 2002 | 01:33 AM
You can reset it at anytime by yourself. As Beiruty stated... INSTRUCTIONS ARE IN THE MANUAL...
No need to have a dealer change the oil if you are comfortable with doing it yourself. The dealer may balk at the Mobil 1 oil... they supposedly have service bulletins that only allow them to use HONDA 5W20 oil???
I reset my light at 5K miles (before the light ever came on) because I had already changed my oil. I now have 9,000 miles and the light has yet to come on. It must reset back to zero regardless of what the mileage is when you reset it.
Old Oct 31, 2002 | 07:30 AM
FTM-1's Avatar
Thats not the Check Engine Light its the Maitenace Required Light.
But as siad thats normal for it to come on at that mileage. Just read your owners manual on how to reset it if you do not take it to the dealer for service.
Old Nov 1, 2002 | 11:20 AM
hgiljr's Avatar
WHICH OIL Weight
I will be doing my own oil change, now which weight of oil should I use?
Old Nov 1, 2002 | 11:24 AM
roadman's Avatar
Re: WHICH OIL Weight
You have many choices, Dino, blended or full synthetic in weights 0w-30, 5w-20 and 5w-30, the choice is yours. A search will get all the info you ever wanted
Old Nov 1, 2002 | 11:44 AM
juniorbean's Avatar
Lightbulb Re: Re: WHICH OIL Weight
Acura's recommendation on the TL is 5w-20. It should indicate this on your oil cap as well as in the manual. I believe the manual also states that 5w-30 may be used... but check it to verify....
Yikes
May 3, 2021 04:29 PM
fifer16
1G RL (1996-2004)
Oct 16, 2015 08:54 AM
Billu99tl
Sep 13, 2015 11:30 AM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
