Check Engine is on
Old Jan 12, 2004 | 08:23 AM
Geneg's Avatar
Check Engine is on
I got check engine light on after very cold weather start.
What would be first fix, reseting ECU?
Old Jan 12, 2004 | 09:07 AM
FidizzyTypeS's Avatar
make sure your gas cap is on tight and then make sure your oil levels are good...then reset your ecu.
Old Jan 12, 2004 | 11:16 AM
RobDDD's Avatar
I had the same problem. How do you reset the ECU? Could it be the fuel?
Old Jan 12, 2004 | 01:17 PM
Geneg's Avatar
I just did my reset. Neg battery contact -disconnect, press brake pedal, neg bat contact-back, all set. Light is gone, atleast for now.
Be sure that you have your radio code handy to set your radio.
Old Jan 12, 2004 | 01:38 PM
mentl's Avatar
Originally posted by Geneg
press brake pedal
What does that do? I reset mine on Saturday, but didn't press the brake pedal.
Old Jan 12, 2004 | 01:42 PM
bbznyc's Avatar
What a coincidence... my check engine light came on too.... hahaha..... i think acura has a secret programming which goes when there is a weather change or something... this way we go to a dealer and spend money....
this is so funny....... i love this....
Old Jan 12, 2004 | 03:09 PM
fsttyms1's Avatar
its cold here and never had the check engine light go on in the winter in 132,000 miles of driving
oh and you dont need to press the brake
Old Jan 12, 2004 | 06:37 PM
vinovelo's Avatar
In line with this topic, if a light comes on and reset does
not work, where is the diagnostic connector for a scanner.
(I have a scanner but have yet to find the connector).
/Steve
Old Jan 12, 2004 | 06:39 PM
Autozone will check ur OBD codes for free go there.
Old Jan 13, 2004 | 12:28 AM
blulegend's Avatar
bluLEGEND
I had this happen. The dealer told me to make sure I turn the fuel cap for at least 5 clicks. I always make sure it's tight but he said sometimes it's not tight enough and vapor leaks out making the computer think something is wrong with the vapor recovery system.
Took the car to the dealer and 20 min later walked out with a washed car and no more light. I should've told them not to wash but I didn't think they were gonna wash it for such a small fix.
Yikes
May 3, 2021 04:29 PM
fifer16
1G RL (1996-2004)
Oct 16, 2015 08:54 AM
Billu99tl
Sep 13, 2015 11:30 AM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
