cheapest power?
Old Jan 6, 2005 | 10:05 PM
jdub7697's Avatar
cheapest power?
looking for the cheapest power, not cheap power.
suggestions please
Old Jan 6, 2005 | 10:38 PM
moahdriven's Avatar
i
Cai
Old Jan 6, 2005 | 10:45 PM
AustNMike's Avatar
Hmm...Is that right??
Originally Posted by moahdriven
Cai
if not, then at least remove resonator.
also, underdrive pulley is fairly inexpensive depending on your labor options. from what is said here, seems like it might be the best gain for the money.
Old Jan 6, 2005 | 10:56 PM
jdub7697's Avatar
got an AEM CAI on the way
Old Jan 7, 2005 | 12:24 AM
keepingitclean's Avatar
i would say pulleys are probably the cheapest power because it provides usable power even in the lower rpms
Old Jan 7, 2005 | 02:32 AM
NsX_XsN's Avatar
what is the best CAI to get for my car acura tl-s
Old Jan 7, 2005 | 06:52 AM
pmptx's Avatar
Honda+Blue=My garage
Do a search there are a billion threads on this. It really depends on the end goal-sound, power, both. Comptech Icebox delivers the most stock sound, and slightly more hp, read slightly. AEI is a throatier sound, I went with the icebox as I don't need the neighborhood knowing when I am driving down the street.
Old Jan 7, 2005 | 08:50 AM
etxxz's Avatar
@ slide or die @
turn off your A/C
Old Jan 7, 2005 | 09:17 AM
bkzjimmy's Avatar
NiGhT rIdEr
which resonator are you talking about??
Old Jan 7, 2005 | 10:06 AM
Elementz's Avatar
UR crank pulley...
Old Jan 7, 2005 | 10:45 AM
fsttyms1's Avatar
cai or UR crank pully
Old Jan 7, 2005 | 12:43 PM
AustNMike's Avatar
I was talking about the airbox resonator....not much power I know. didn't think of the exhaust resonator, but that might give a small gain too.
and yeah, I forgot to type "crank" in my pulley sentence....
Old Jan 15, 2005 | 02:35 PM
Team Nighthawk Member
aprox how much of a difference will it make if u take out the intake resonator
Old Jan 15, 2005 | 03:16 PM
shawn744's Avatar
Kollage is funn!
a resonator doesn't really give that much hp...a true CAI will give about 4-5.....if that.....
Old Jan 15, 2005 | 03:22 PM
so should i waste me time taking it off?
Old Jan 15, 2005 | 03:56 PM
aaronnn's Avatar
it makes a realllyy nice sound if you remove the resonator. the air suction is crazy at higher rpm's. but if youre just looking for increase in power, than its not much at all. but if you want to do a CAI dont you have to remove the resonator anyways? so that the CAI can go all the way to the bottom?
Old Jan 16, 2005 | 10:09 AM
dwstormes's Avatar
5th Gear
I believe the biggest bank for the buck is a cold-air induction system. Should add about 10 HP. I've got the Comptech one. Look at the Comptech web site for dyno results. After that, without major engine mods, is cat-back exhaust. But it cost about $1000 (not just the two rear mufflers but from the converter back) and only adds at the most another 10 HP. I have heard that adding both the air induction and cat-back exhaust is complementary so that the net increase of both is more than each individually. Next are headers which cost around another $1000 plus installation. If you have driveway mechanic savy you can do the intake and exhaust yourself but the headers are much more complicated and you may need to raise the car more than you can in your garage.
Old Jan 16, 2005 | 10:31 AM
ou sig's Avatar
Boomer SOONER
sorry a cat back on our cars doesnt add much at all...I mean 2 or 3 whp. Best bang for the buck is either the UR crank pulley or some headers. They woke my engine up to say the least, much more fun to drive now. Also, removing the resonator has to add HP. I mean look at what your engine was breathing through before then after...95% the same design as the Comptech Icebox. I did that before my headers, and I swear there was more HP up high, just like a new intake.
So save your money, get a K&N filter and take off the intake resonator.
Old Jan 16, 2005 | 10:41 AM
ou sig's Avatar
Boomer SOONER
edit...a full exhaust, header and cat back will be worthwhile if you have forced induction (supercharger or Turbo), other than that, our stock exhaust (header back) is pletty free flowing.
Old Jan 16, 2005 | 09:50 PM
aaronnn's Avatar
there's an incredible, noticeable kick when you remove the resonator and pop in a K&N Filter, which goes for 35-50 dollars. definitly the cheapest. and the engine roars and sounds beautiful. took me less than half an hour to remove resonator and another 10 minutes to drive out to pepboys to cop me a brand new k&n filter.
Old Jan 17, 2005 | 01:55 PM
1fasttl's Avatar
Cheapest power? Test pipe!!! Take off your cat and put a staright pipe, you will notice a big ass gain. The only down fall is you will get a check engine light.
Old Jan 17, 2005 | 02:01 PM
NYZGREATST's Avatar
Sig Rho's Finest
i concur with the rest. CAI or UR Crank Pulley
Old Jan 17, 2005 | 02:40 PM
z3Ro's Avatar
Mr. 2tone
if u replace the cat with a straight pipe...wouldnt that just make u fail ur smog check?...n i believe u can bypass that engine light with a simulator...
Old Jan 17, 2005 | 02:44 PM
1fasttl's Avatar
Well everyone knows you will fail smog if you remove it but like i said if you get a flanged test pipe you can always put it on when it comes time to smog just like i have.
Old Jan 18, 2005 | 12:29 AM
z3Ro's Avatar
Mr. 2tone
whats a flanged test pipe?...u mean like a bolt on test pipe...lol...kuz thatll b sick
Acura604
20
Aug 5, 2017 12:55 AM
spudweb
May 22, 2016 02:39 PM
knight rider
Mar 4, 2016 08:59 AM
mars
Sep 28, 2015 11:03 AM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
