Changing inner tie rod
Old May 29, 2009 | 01:48 AM
wdptls88's Avatar
I am about to change out my inner tie rod cause it's worn and thinking of doing this on my own. I have access to air tools.
Has anyone changed it out on their own before and can shed some knowledge so it will be an easier process for me?
Will be changing out the front left inner tie rod.
Old May 29, 2009 | 05:36 AM
01tl4tl's Avatar
get a picklefork tool or borrow the tool at parts store
Measure the length of the threads to nut on the old tie rod so the new one gets set close
then take it for an alignment
Old May 29, 2009 | 03:01 PM
TLer trash's Avatar
I haven't used a pickle fork in years. They almost always tear the boot. If you hit the casting where the outer tie rod tapered stud goes through with a hammer, the tie rod end will pop out easily. You will also need a new clamp for the rack bellows and most likely an inner tie rod end tool. Count the threads on your old one, like 01 mentioned, but I'd still get the alignment/toe checked.
Old May 29, 2009 | 03:05 PM
fsttyms1's Avatar
Tearing the boot wont matter because the new one will have it. You can buy a new boot OEM for 1.40$ if you doo tear one and you need to replace it.
Old May 29, 2009 | 03:28 PM
01tl4tl's Avatar
there is a press type clamp I couldnt remember the name of that works too
parts stores loan that one out
Old May 29, 2009 | 04:40 PM
TLer trash's Avatar
What I was trying to get at is everybody has a hammer or two, while most don't have a pickle fork or tie rod end press. Once you've tried the hammer way, I think it's easier and faster too. Nobody seems to stock outer tie rod boots around here although I know they are cheap. The o.p. didn't mention doing the outer end, so he wouldn't have the outer boot. They are nearly impossible to get for domestic and aftermarket parts. I keep an assortment of energy suspension boots because of this. One more tip is to loosen the jamb nut at the outer end before you separate the outer end. It's easier that way.
Old Feb 17, 2010 | 05:25 AM
TLDude876's Avatar
Chapter Leader (Houston)
My right side inner tie rod end needs replacing. Is it necessary to go ahead and change both sides? Are the aftermarket ones any good? They come with a lifetime warranty.
Old May 4, 2010 | 08:03 PM
JMAL's Avatar
i have to replace my inner tie rods. is there a diy, i cant find one.
Old May 4, 2010 | 08:15 PM
fobstylez's Avatar
what symptoms occur from a bad tie rod?
Old May 4, 2010 | 08:27 PM
JMAL's Avatar
The car wanders a lot on uneven pavement and the steering wheel is a little loose and numb feeling. also with the car off and on the ground, wiggling the steering wheel makes a clunking sound. I confirmed it by having someone wiggle while i felt the tie rod, and left a lack of solid connection when wiggling at the inner tie rod around the boot to the steering rack.
Old May 4, 2010 | 08:36 PM
my.daily'tl''s Avatar
Always Working In
Very easy. I use a pitman puller for the ball joints. Never tears the boots. Take off wheel. Take out cotter pin and loosen ball joint with puller. Measure where your old rod sits and set so you can set new one as close as mentioned above. Take off boot covering inner tie rod. Take out inner tie rod with wrench. Now youre ready for your new parts. Dont really have anything else to say about it its really simple. Wish i had the torque specs in front of me. Im sure theyre here somewhere.
Old May 4, 2010 | 10:36 PM
JMAL's Avatar
do you have to count the turns for the inner tie rod too?
Old May 5, 2010 | 05:44 AM
Always Working In
The outer tie rod is where the toe alignment adjustments are made. The outer rod has a locking nut behind it. Somepeople count the turns but you're replacing the set. I'd recomend getting the new one as close as possible and getting an alignment. Good place is tires plus. I just got an alignment with a 3yr warr for 99 bucks. GL
Old May 5, 2010 | 12:21 PM
rcb2000's Avatar
it's easier to lay the old tie rod next to the new one matching the ends up, then marking the new tie rod with a piece of chalk, you should see a difference in the color of the threads the exposed thread will be rusted or dirty the threads that where inside of the sleeve will be farly clean.
Old May 6, 2010 | 04:11 PM
JMAL's Avatar
the boot strap on the inner part of the inner rod, is that reusable? if not where can i get that, any parts store?
Old May 6, 2010 | 06:32 PM
Always Working In
I'm pretty sure you can. Make sure the boot isnt ripped or has any holes in there.
marcelft
Jul 10, 2018 06:17 PM
IlliniAcura
Sep 19, 2015 09:31 PM
Sep 14, 2015 10:09 PM
Aleax
Sep 11, 2015 11:31 AM
