Changing the glove box light?
Old Mar 11, 2002 | 07:18 PM
mbeebe's Avatar
TL Type-S Owner
Question Changing the glove box light?
Pure and simple, how do I get to the glove box light?
Old Mar 11, 2002 | 07:20 PM
oracion's Avatar
Question
How about the center console light? I don't like the green light.
Old Mar 11, 2002 | 08:05 PM
ElegantTL-S's Avatar
¤ Club Inspire ¤
I was trying to figure that out as well. It appears you'll need to move the glove box out of the way first...then figure out how to remove that whole cover. haha. too much trouble just for bulb IMO.
Old Mar 11, 2002 | 10:06 PM
lilboykorea's Avatar
do u drive with ur glovebox open? ..hehe
its not worth the hassle...
Old Mar 11, 2002 | 10:12 PM
mbeebe's Avatar
TL Type-S Owner
This is why you all are supposed to help. It looks tough, but looks can be decieving, has anyone actually done it?
Also, the center console consists of many LED's and takes a TON of work to do. Nate did it though.
Old Mar 11, 2002 | 11:10 PM
snorlax52c's Avatar
yay i finally get to help
i just did the glove box last weekend. first you have to take off the fuse cover. easy just pull it out. then open the glove box. around it you will see i believe 4 screw lining the box. remove those and you'll be able to pull the box out at an angle enough to replace the bulb.
with the consol i figured out that you can take the green filter off. but you still can't get to the bulb. so i gave up
i think the only way to get to that one is to remove the whole console.
if anyone knows a way to replace the console bulb without removing the whole console please do tell
Old Apr 12, 2013 | 11:29 PM
niha17's Avatar
All you have to do is take the little plastic circle cap off and pull the black cover out to get to the light. Then all you have to do is turn the plastic cap 90 degrees and pull then the bulb is there. Its a 2 minute job. It a real small bulb This goes for both the glove box and center console.
Old Sep 16, 2019 | 10:55 PM
Darksyne's Avatar
Sorry for reviving an ancient thread but I came around to replacing the glove box light with an LED to work on having an all LED interior. Here are some visual aids if anybody else is interested in doing the same thing to their TL.
Fuse panel also located here.
Best to change the cabin filters while doing all this work.
Sorry if it’s difficult to notice the difference as I did this during the day.
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
sputik
Sep 7, 2015 01:40 PM
bymotion
Aug 31, 2015 05:00 PM
