Center Console Shift lights
Old May 17, 2005 | 05:16 PM
MikeS's Avatar
My center console shifter light that lights up each gear went out. Any ideas on how to get to it to replace it?
Thanks....
Old May 17, 2005 | 05:35 PM
fsttyms1's Avatar
off the top of my head, pull off the 2 trim rings that go around the shifter, then pull up on the piece that has all the gear #'s and you will see the bulb
Old May 17, 2005 | 08:48 PM
SilverIce2000's Avatar
i have the same problem.. it looks like it went out- but if you TAP it from the top on the chrome/aluminum piece hard enuff... it should turn back on.. GHETTO- YES... but thats how it works for me haha
Old May 17, 2005 | 09:23 PM
varunverma23's Avatar
Put LED's in it:
http://www.imagestation.com/album/pi...26578450&idx=1
Old May 17, 2005 | 09:56 PM
FFWDGRAPHX's Avatar
Originally Posted by varunverma23
I created an account with imagestation.com just so I can view ONE picture??
Anyways, did you do this yourself? Do you have a DIY?
JQ
Old May 17, 2005 | 10:35 PM
yah i already had one that i didnt use-----it wont let me post pics.
I got indivudual letters made n took out the old ones because they had that stupid green filter in them and wouldnt let white light through.
Old May 17, 2005 | 11:14 PM
guavawang's Avatar
i was looking at changing that!!
where can i buy the led and the DIY to do it??
please tell me..
thanks
Old May 17, 2005 | 11:41 PM
around the factory bulb is a clear diffuser thing that spreads the light all around.
i put two 5mm led's facing 45 degrees and 135 degrees in a kind of V shape and melted some of that plastic diffuser to make room for them.
And i got letters printed on clear vinyl so the light shines through just the letter part.
but since its clear, you need to stick them on something white so u can see the white letters, i stuck them on a white grocery bag and cut around
sounds kinda funny but looks perfect.
Old May 19, 2005 | 12:16 AM
SC2.2CL's Avatar
Mine went out too, I paid about $4 for the stock part. You will have to remove the arm rest and center console and ashtray. There is a DIY in the AV forum. Then you push the clips on the black light sorround one at a time and lift up gently. I started with the one on the rear passanger side. Once the black plate it free, twist the base of the bulb and the socket comes right out. The part I got had a bulb and socket, just pull out the bulb and replace. It took about 40 min b/c of the console. A lot easier than the LED parts
Feb 25, 2020 09:57 AM
james357
Feb 13, 2016 02:37 PM
bymotion
Nov 18, 2015 11:28 AM
PortlandRL
Sep 14, 2015 12:01 PM
