CD changer Error E1
![Post](https://acurazine.com/forums/images/icons/icon1.gif)
Has anyone had that problem on their Cd changer on th TL-S? I pressed on the EKECT button and suddenly it say Er-E1.
How can I fix that without bringing it to the dealer?
First, wip out the manual for the CD player and find out what that error means. THere is a list of error codes for the CD player. If you can't rectify the problem yourslef, I would take it back to the dealer because it is still under warranty. Good luck.
Those who know, don't talk.
Guest
Posts: n/a
I had this problem. It seems that I used my own CD with labels and tried ejecting, the CD began to peel at the edge and got stuck coming out.
I simple tried to grip the exposed CD at the opening and pulled it out. Part of ther CD label ripped as it came out.
Warning: Do not use CD with stomped custom labels. They will heat up in the CD player and loosen up. When you eject the CD the label will peel and stick or jam.
Good luck trying to get the CD it out.
Guest
Posts: n/a
It's sad that only because the CD changer is blocked (can't eject), they have to change the whole unit.
![](http://www.acura-tl.com/ubb/frown.gif)
Guest
Posts: n/a
It's sad that only because the CD changer is blocked (can't eject), they have to change the whole unit. ![](http://www.acura-tl.com/ubb/frown.gif)
[/B][/QUOTE]
Do you make your own CD's and stick labels on them. If you do - don't do it again or you will be changing your CD unit on a regular basis!
[/B][/QUOTE]
![Exclamation](https://acurazine.com/forums/images/icons/icon4.gif)
[/B]Do you make your own CD's and stick labels on them. If you do - don't do it again or you will be changing your CD unit on a regular basis![/B]
Any you'll be paying to have it done. If it's damaged by a CD label and the dealer sees this it will not be covered under warranty!
'02 Acura TL-S
Satin Silver/Ebony, w/out NAV
<FONT COLOR="#800080" SIZE="1" FACE="Verdana, Arial">[This message has been edited by imax on May 16, 2001 @ ]</font>
'02 Acura TL-S
Originally posted by imax:
Do you make your own CD's and stick labels on them. If you do - don't do it again or you will be changing your CD unit on a regular basis![/b]
[/B]
[/B]
phillyguerrilla
09-26-2015 11:27 AM
