cat cover?????
cat cover?????
i got these megan headers.
they've been rattling since i got them.
i took off the catalytic conv cover.
now the rattling is gone.
HOW LONG CAN DRIVE WITH THE CAT HEAT SHIELD OFF?.
I need 2 more gears
I would just a new heat shield and bolt it back on tight, then it won't rattle. Mine heat shield rattles too and I found out it was a bolt that rusted off, so tomorrow I will use a steel clamp to fix it, no big deal.
I need 2 more gears
The heat shield is there for a reason. I personally want it there, especially in the fall when leaves are everywhere! I have an oversized hose clamp I will be installing today to get rid of the rattle.
2400 Watts in a TL...Why?
1 Post
The Fix The The Problem, And Keeping The Cat Cover
The key is finding four bolts that are approx 2 inches in legngh.. inch and a half would work but it's easier with two inch.
1. Remove the bolts holding the cat cover on .
2. Get four new, longer bolts to use in place of the stock cat cover bolts.
3. Attach the new bolts to the one side of the cat cover,
4. Now on the opposite side of the (first) cat cover, attach two nuts to each bolt..
5. Then put the (first) cat cover onto the cat under the car.
6. Now attach another two nuts onto each of the bolts holding the (first) cat cover to the cat.
7. Attach the (second) cat cover to the cat, you may need to drill out the nuts welded to the (second) cat cover. Depending on the replacement bolts you choose, the ones I had lying around in the garage had a different thread pattern then the stock nuts so the replacement bolts would not properly screw into them. I quickly drilled out the center of the nuts to fix that problem.
8. Finally, attach another nut to each of the bolts, thus keeping everything, each cat cover and the cat, properly secured together, and spaced (by the nuts in steps 4 and 6) apart enough to clear the flange causing the ratteling.
Tada... Your cat cover is now properly on your car, spaced away from the cat, and it only took an hour MAX of your time..
I need 2 more gears
very detailed DIY for such an easy task. I said screw it and just took mine off today. All the bolts were rusted and ready to fall off, I know because when I took my raquet to them the heads on the bolts broke off very easily. I will probably get a new cat sooner or later anyway as mine has 116+k miles on it and the flanges are very rusted also. The rest of my exhaust looks great, but the cat is nasty looking. No more rattles now either and after a little over a year my Stones are looking great and not that much resonsnce at all.
mlody
12-04-2019 02:11 PM
InFaMouSLink
10-27-2015 06:52 PM
