Car went in today for repairs.
UB6IB9
Everything that needed to be repaired will be repaired,nothing spared.
1 ball joint,overheating problem(but hasn't overheated in over a week.),oil press switch,rear main seal,timing belt/water pump,valve adjustment,rough idle rotors and pads and anything else we'll find. Let's just hope the bill won't be astronomical!!!Last but not least,going in for a detail.
It's the Halladay season!
Good luck with it, ready for another 100k of use!
The Dumb One
holy 2300 dollar service...
would been 1500 at a honda/acura specialist shop
but it will last you much longer after all is said and done. congrats on being able to shell it out though.. i do mine piece by piece lol.
If you took it the Acura dealership...my guess would be north of $3000 easy!
I had a rear main seal leak that was replace under warrenty ($1400 if i had payed out of pocket)
100k Tuneup (i.e. timming/tennsion belt/water pump/ spark plugs) $1000
That is almost $2500 without the other repaired done.
It would be a good idea to replace any bad motor mounts when they replace the rear main seal! (no additional cost via labor)
UB6IB9
My quote for timing belt water pump seals and what not is 750$.They replace anything they can while they're at it.
have the tensioners and idler pullies replaced now while its apart
S E L L
UB6IB9
So here is a list of things that got done on my car.
Timing belt
Water pump
Idler
tensioner
damper
cam seals
rear main seal
adjust valves
clean entire intake and unclog egr port
clean iacv
control arm
cooling system purge
thermostat
temp sensor
oil pressure switch
new gaskets
getting new slotted rotors and pads
ss brake lines
new brake fluid
new plugs
All this for a grand total of $2200.
Timing belt
Water pump
Idler
tensioner
damper
cam seals
rear main seal
adjust valves
clean iacv
control arm
thermostat
temp sensor
oil pressure switch
new gaskets
ss brake lines
new brake fluid
new plugs
UB6IB9
NGK Iridium IX plugs. Car rides like new,literally!!I haven't installed the brakes yet.The mechanic told me the egr port was entirely clogged.He let the whole intake soak up while he was working on the car. I noticed blue smoke when i accelerated ,but he said it's gonna go away by tomorrow.I guess some cleaner and oil fell inside the cylinders.Now the car is super smooth.
may as well change them with this service-
they are all critical parts and with over 100k miles and 10 years on them.....suspect~
I would change all the rubber radiator hoses too
Those blow out and you have a major problem
UB6IB9
UB6IB9
I changed the thermostat first when my car started overheating,that didn't solve the problem.The oil pressure switch was leaking and the temp sensor n was causing the overheating so i had to replace it.
UB6IB9
I haven't changed the rad hoses they still look good,but might as well change them,anything else i should be replacing??
bearingman07936
01-07-2016 03:22 PM
