Car Theft
Head Wanker
Yep, our cars have the immobilizers linked to our key fob but a while ago, I read two posts where TL owners got their car stolens by being lifted right flat bed trucks and driven away. When crooks really want something bad, they'll figure out a way. Bastards.
There is a way to disable our immobilizer, and someone even posted instructions here over a year ago (Instructions were later deleted by Moderator). And it was pretty easy too. So do not count on OEM system too much.
OEM or Aftermarket Alarms are useless, when a theif really wants something. The thief will find a way to get to it and get it. However I have onstar, and that is the only thing that I beleve can't be disabled, which can be used to locate the car. However, Im pretty sure there is somethign that the thief can do about this too.
I was told by some dealers when thiefs want the car they leave the LoJack in place of the car.... don't know if its true but I go along with if thiefs want something, THEY WILL TAKE IT!
the immobilizer thing works by linking a comp chip in your key fob with a chip in the engine. everytime you use it, they generate a code and if you want the engine to start, you have to have both the key fob chip and the engine comp chip to match the code. Otherwise the engine won't start. There are ways to get around it. I think Jaguar was the first to put this system in their cars. If you watch "Gone in 60 seconds" they steal a Jag that has the immobilizer system on it. THat's my 2 cents
Need a WHAmbulance
Not too hard to steal a TL. Just get a copy of the valet key. Open the door, open the hood replace the ECU with one that has the imobilizer taken out and away they go.
I read that somewhere on this forum but can't find it now.
Head Wanker
1) Know where you put your valet key and appropriate it
2) Possess an ECU specifically for the TL with the Immobilizer disabled
If this happened to anyone, that person wouldn't be the victim of some random crime. It means he pissed off someone really, really bad and is tasting the bitter tang of someone's exacting revenge.
Something like an ex-wife would do...
Dragging knees in
LoJack is hard to disable. They don't disclose the location of the transponder unit even to the owner of the vehicle. Only LoJack knows it. So if the thieves wanted to disable it, they are going to have to spend quite a bit of time.
As for OnStar, just rip out of the antenna and it becomes useless. It's only helpful when an idiot teenager steals your car for a joyride and doesn't know anything about OnStar.
Need a WHAmbulance
Originally Posted by wanker256
Did this really happen in real life because thieves are almost always opportunists. To have this happen, the thief would have to:
Also the remote keyfob works on a FM frequency (very low power). How hard would it be to pick up your paticular frequency sitting in a mall parking lot close to your car and transmit the frequency back after you have walked away. Now the car is completely open. He just can't start it without the chip in the key but the alarm won't go off.
Dragging knees in
I would agree the the majority of thieves :chainsaw: are opportunists. There are professional car theft rings that live and die by the cars they steal. All it would take is a valet working for a theft ring to get ahold of your valet key, he gets your address from your license plate # or something in the car. Show up late one night and away he goes.
Originally Posted by Pure Adrenaline
LoJack is hard to disable. They don't disclose the location of the transponder unit even to the owner of the vehicle. Only LoJack knows it. So if the thieves wanted to disable it, they are going to have to spend quite a bit of time..
