Car shut off while driving
Old Jul 29, 2019 | 03:49 PM
vip_inspire's Avatar
is making xxx movies
I was driving home today and literally around the corner from my house my car shut off and wouldn't start back. It has a full tank of gas. So no gas isn't the issue. When I turn the key nothing on the instrument panel lights up, the starter doesn't click or anything. Thankfully I was walking distance from home and just pushed the car home. Any idea of what my problem can be? This is totally random and has never happened before. I checked voltage on the battery and it's good as well. Please help AZ, I need my car to at least last the rest of the year lol. I know it's old and has had its good days but for an 03 with less than 120k miles I shouldn't be experiencing this issue. I can deal with a blown tranny. Something leads me to think it's an electrical issue
Old Jul 29, 2019 | 03:51 PM
Did you check to see if the connections to the battery were good and actually connected?
Old Jul 29, 2019 | 04:02 PM
Yes everything is good on that part. When you turn the ignition switch to on you don't hear the fuel pump and nothing lights up on instrument panel
Old Jul 29, 2019 | 04:14 PM
perhaps the main relay, also called the fuel main relay.
Old Jul 29, 2019 | 04:34 PM
How can I check main relay besides going and buying another one and swapping it out?
Old Jul 29, 2019 | 05:12 PM
whitetiger5's Avatar
There's a very comprehensive troubleshooting process in the service manual. page 11-160.
Old Jul 29, 2019 | 05:15 PM
Isn't the pdf for the manual on here somewhere?
Old Jul 30, 2019 | 03:37 AM
01acls's Avatar
Do the brake lights work?
Old Jul 30, 2019 | 04:13 AM
Yes brake lights work, last week I literally had to change the brake light switch. I am starting to think it's ignition related because the car has power and once any of my keys are inserted it makes the sound that a key is in while the door is open. I'm trying to figure out if it is a simple fix or if I have to just get it towed to my mechanic and have him deal with the issue
Old Jul 30, 2019 | 08:01 AM
01acls's Avatar
35130-s84-a01
Old Jul 30, 2019 | 08:15 AM
I wouldn't have to rekey my ignition with that correct?
Old Jul 30, 2019 | 08:16 AM
01acls's Avatar
Correct, no rekey.
Old Jul 30, 2019 | 08:24 AM
Originally Posted by 01acls
Correct, no rekey.
Just ordered the part $48, is there a diy anywhere on the site?
Old Jul 30, 2019 | 08:34 AM
Never mind on diy I found this old thread from an og
https://acurazine.com/forums/second-...switch-686000/
Old Jul 30, 2019 | 03:00 PM
So after changing out the ignition switch, it's still the same issue. Any other ideas? When I start the car via remote start it starts no issue.
Old Jul 30, 2019 | 06:53 PM
01acls's Avatar
It's complicated, you need the schematic. Changing this next would be my next logical step but the symptoms don't fit a defective main relay a 100 percent.
It could also be a bad electrical connection, like bad power cables?
I'm surprise the ignition switch didn't fix your problem, my baaaddd.
Besides the car dying near your home, what were you and/or the car doing when the car die?
Ruby
Nov 27, 2024 02:20 AM
blilrat
Apr 27, 2018 05:06 AM
Nelliebaby21
4G TL Problems & Fixes
18
Mar 27, 2018 12:17 PM
Joe5.0
May 4, 2012 04:37 AM
4ank
Nov 6, 2005 09:31 PM
