Car Idling problem
Old Sep 18, 2006 | 09:33 AM
Got_3.2?'s Avatar
Car Idling problem
hey
when i put my car in park and emergency brake on my car was going nuts. my car was reving from 1 to about 2rpms going back and forth until i shut the car off and restarted and did the same thing. restarted and it stopped. what can be the problem??
thanks
mike
Old Sep 18, 2006 | 09:49 AM
jleon2516's Avatar
Tristate Vip Crew
sounds like the idle air control valve (iacv). it is located under the throttle body. sometimes cleaning it helps but if after cleaning it you still have the same problem the valve needs to be replaced. Very easy to replace. I have a new one I purchased but never installed. if you need it let me know, good luck.
Old Sep 18, 2006 | 09:52 AM
fsttyms1's Avatar
why did you set the parking brake?
A idle like that sounds like a IAC
Old Sep 18, 2006 | 12:19 PM
Got_3.2?'s Avatar
my driveway is a little steep. so i put the e-brake on. im bringing in my car to get my rear brakes replaced so ill have them check it. i just restarted my car and no rpm jumps. ill let u know jleon thanks
thanks guys.
mike
Old Sep 18, 2006 | 12:34 PM
type-s09's Avatar
13.2@ 107 on Street tires
check your throttle cable..mine did it when i adjusted the cable too tight..it also might be getting hung up
peti1212
ILX
22
Jan 5, 2022 05:14 PM
Mike Bertram
Sep 10, 2015 09:27 AM
jordanboi
Sep 5, 2015 01:33 AM
NSolace
Sep 3, 2015 08:14 PM
darknite123
Integra
Aug 30, 2015 03:00 PM
