Car Dies while driving on Hwy.....
Old Nov 25, 2008 | 10:07 AM
Angry Car Dies while driving on Hwy.....
Hello,
I got a problem with the my 99 TL 157K on it.
I have a new battery installed, idle control valve also changed and less than a week after all those changes the car just dies on the highway in NJ.
I pull over emergency lights on wait a few seconds after full stop and then start no problem. No previous noises before this happens it just sneaks up on you. No lights to warn you of this either.
Could it be the ignition switch? I did change under the recall once. Planning to take it to the dealer but $$.
Any advice on what it could be?
Old Nov 25, 2008 | 10:24 AM
Bob_F's Avatar
Yes, it could be the ignition switch again. The replacements can and do fail.
My 1999 TL is on its third ignition switch. The second one was installed under the recall.
You can buy the part for about $50 online and install it yourself.
Here's a nice DIY thread with photos.
https://acurazine.com/forums/2g-tl-1999-2003-98/diy-99-tl-ignition-switch-686000/
Old Nov 25, 2008 | 10:26 AM
clue036's Avatar
that is definitely the ignition switch. same thing was happening to me about a year ago, got it fixed and the stalling stopped. i believe there is a diy around here if you wanna save some money.
Old Nov 25, 2008 | 03:33 PM
01tl4tl's Avatar
yep- DIY and hope this one last a while
Some parts are just prone to failure, others are made worse by things like hanging several keys on the ring ...causing internal sideways pressure on the ignition switch guts
Old Nov 25, 2008 | 04:49 PM
vivftp's Avatar
*looks at my keychain with 3 additional keys, 2 keychains and the remote on it*
think I should clear off a lot of that excess baggage?
Old Nov 25, 2008 | 11:56 PM
arm5262's Avatar
its the ignition switch for sure. simple test is to hit the ignition switch area with your hand while the car is parked and running and it will shut off.
mine had the same issue. 300$ by dealer they changed the immobilzer first which did not help.
Old Nov 26, 2008 | 10:29 AM
01tl4tl's Avatar
45 bucks and 30 minutes- especially if switch replaced before- this time its easy
for you to do
If you have weight on the keyring-- you may consider a holder that is 2 pieces with a center connector clip- so the car remotes and key can quickly be seperated while in use, then put back together with the rest of your stuff as needed
Old Nov 28, 2008 | 01:33 AM
anything else can cause this beside ignition switch????
thnaks
Old Nov 28, 2008 | 09:16 AM
01tl4tl's Avatar
recheck the install of the IAC would be the next step, why was that replaced??
Has your car been in for the recall install of an egr port thing?
99s get it free,
the rest of us have to remove the intake manifold and clean the egr ports with carb spray and toothbrush~
peti1212
ILX
22
Jan 5, 2022 05:14 PM
Feb 25, 2020 09:57 AM
james357
Feb 13, 2016 02:37 PM
iesu3423
Sep 29, 2015 08:04 AM
jordanboi
Sep 5, 2015 01:33 AM
