Can't get the rotor out!
I need help! I can't get the phillip screws out to remove the rotor! I stripped the head of the screw and there is no way I can unscrew it. I am thinking about drilling through the screw. And if I do that I can put in a new screw. Do I need these screws to hold the rotor in place? Some people said you really don't need that screw because the lug nut is holding the rotor in place. Do you guy have any idea how to remove these screw after the head was stripped?
Thanks!
Thanks!
Originally Posted by tweedle99
You don't need to put the screws back in. They were there to assist during assembly.
Drilling it is your best choice unless you got one of them "screw-out"
Originally Posted by nick04tl
use a chisel or punch to get it out. it should break loose on the first hit and spin out with your finger. did you use an impact driver to break the screw loose?
Jul 16, 2017 07:33 AM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
lanechanger
Oct 13, 2015 10:56 AM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
