Can't Find Software!!
My research tells me that the problem I have not being able to set the clock in my 2003 3.2 TL has to do with a software "glitch". Something to do with Acura changing/modifying a satellite signal around 2003 which, for whatever reason, only affected not being able to set the clock. The solution, I was advised, was to reinstall the original software that came with the car which, naturally, I don't have. YouTube made it look pretty straightforward...until it got to the disk that I don't have. Is there really a solution for this or should I just learn to live with 0:00 on my screen?
As mentioned, I have searched the site and Googled my concern and while there have been suggestions, none have panned out. I have to believe that the original disk I need must exist somewhere!
Thanks!
Thanks!
PATRICKPBME (05-02-2018)
My disk says ver.2.05A. It started happening about a year ago where it would only show 0:00 then after a minth or so it started working but now goes an hour ahead or behind and when I go to adjust the hour +- it goes back to 0:00. I just minimize the time on the nav now and use the clock on my headunit but it still bothers me untill daylight savings rolls around.
I have version 2.70A. I will let you know how the disc being sent works. You might want to get ahead of the curve by using the link below to get to Acura and have an on-line chat. Have your VIN available. They may need to send you a different disc than they are sending me. They are extremely helpful.
https://www.acura.com/contact-us?Sec...m-requirements
juniorbean
Technology
19
01-20-2009 06:47 PM
icy CL
Technology
10-14-2005 10:25 AM
dfreder371
08-21-2003 01:11 PM
