Cabin Air Intake
Old Aug 4, 2008 | 02:44 PM
Superb's Avatar
should i spend more in
Cabin Air Intake
I have a water leak coming from my cabin air intake. Can anyone shed some light on how to access this from inside the car?
Old Aug 4, 2008 | 08:34 PM
Superb's Avatar
bump!
Old Aug 4, 2008 | 08:42 PM
achen0122's Avatar
are you talking about your cabin air filter?
Old Aug 4, 2008 | 09:59 PM
01tl4tl's Avatar
look in the DIY cabin air filter replacement
remove glovebox- behind that is the air filter cover- behind that is the blower motor- heater core and vent intake and such
Old Aug 4, 2008 | 10:05 PM
totaledTL's Avatar
That sounds like the evaporator drain is clogged- check that.
Old Aug 5, 2008 | 08:31 AM
Superb's Avatar
It only does it when it rains, so i used a garden hose to check various areas and it comes in when i spray in the middle of the windshield. so i got under the dash on the driver's side and cut back the dashboard material to follow the water and it led to the blower motor, vent intake area...
Old Aug 5, 2008 | 08:54 AM
totaledTL's Avatar
Ok, good luck with that one. Haven't seen that problem before.
Old Aug 5, 2008 | 10:04 AM
Superb's Avatar
yea, i've done tons of searches and typ its a sunroof drain clog or something of that nature, seems like i'm the lucky guy that gets this odd ball.... anyway, i'm guessing some debris got into the cowl and has now clogged the drain in it and its overflowing into the heater core or whatever that big black box is that is attached to the firewall behind the radio
tsx_boy
Dec 13, 2019 08:33 PM
Jul 16, 2017 07:33 AM
rcs86
Aug 2, 2016 06:52 PM
hashbrown
Sep 29, 2015 12:13 PM
