A/c problem
Old Mar 29, 2012 | 01:39 PM
A/c problem
i have a 2000 tl a/c blowing out warm air compressor making a noise when engaged put a set of gauges my high side is 300 my low side is 20 and suggestions?
Old Apr 4, 2012 | 01:38 PM
jdjohn84's Avatar
2003 TL-S w/Navi NBP
20psi on the low side is too low. You probably have a leak somewhere in the system...maybe just a small one that takes awhile to leak out. 300psi on the high side is acceptable, especially in your warm climate. Sounds like you need to charge the system with refrigerant. Once charged, the low side should read at least 30...probably more like 40-45 where you live.
Old Apr 5, 2012 | 11:07 AM
TLer trash's Avatar
300 sound a little high to me if you are in fact low on charge. Are BOTH of the radiator/condensor fans on whenever the compressor engages? Is the hot water control valve closed all the way?
Mike Pilipenko
Mar 26, 2024 09:21 PM
SidhuSaaB
May 30, 2020 12:40 AM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
