A/C Filters
Old Apr 5, 2002 | 09:42 AM
David Johnson's Avatar
8th Gear
A/C Filters
Has any one in this group had a chance to located and replace the filters for the airconditioning and heating system? I understand there are two of them and was wondering where they are located and how to access them.
Also I would like to know where to purchase the Inspire rear deck shade that some of you have on your TL Type S.
Old Apr 5, 2002 | 10:17 AM
The AC filter are behind the glove box. You need the HELMS service manual to do the change!
Old Apr 5, 2002 | 05:04 PM
sotiri's Avatar
Curious, has anyone found if we can subsitute charcoal filters with better filtration, and odor removal?
Old Apr 5, 2002 | 05:14 PM
fla-tls's Avatar
On the way!
Instructions
David, these instructions were posted a while back. They seem to work well enough to get the job done.
open the glove box. on the right side you will see a shock holding the glove box in place, remove the screw
see those tabs in each top corner of the box that prevent it from falling forward? remove those by putting pressure on the back side of them (this is a little hard the first time)
remove 2 screws at the bottom corners on the outside of the glove box (one in each corner) the box should come out.
cut the tabs (i think they’re labeled) for the square shaped plastic. replace the filters. put it all back together
i think i covered everything
Biggie_B
May 27, 2025 05:51 PM
rcs86
Aug 2, 2016 06:52 PM
knight rider
Mar 4, 2016 08:59 AM
LeVeL
Oct 18, 2015 04:19 PM
hashbrown
Sep 29, 2015 12:13 PM
