A/C AUTO light stays on :(
Hi,
My A/C unit always shows AUTO... I cant turn it off.. If I press the Auto butoon It changes to FULL AUTO.. But I cant turn the AUTO off.. any suggestions?
The Acura Tranny Killer
FULL AUTO means that both blowing and 'location' of the airflow is done automatically.
AUTO means that the 'location' is done automatically with the blowing power set by the dial.
Press the button that sets the location of the airflow (the vents) and it'll remove the AUTO.
Tracer
Tracer
auto always shows on mine nomatter what button you press, unless you turn the fan speed to the straight up position and hit the auto button, then it says full auto
if you don't want it to say auto then press mode
auto means it will automatically "sense" which area needs the air...so if you tell it you just want feet and face just hit mode until u get the desired parts where u are hot/cold...
Damn.. then there is something wrong with my car .. even when I press mode so the fan is set to desired position it still shows auto.
auto always shows, or atleast it has in mine for the last 158,000 miles.
no matter what position its in or what mode the word auto shows
It still stays on... cant turn it off. I thought If I turned the fan to a different position it would go away but no luck.
what about if you press the A/C button?
nope tried that.. no luck ![Frown](https://acurazine.com/forums/images/smilies/frown.gif)
Originally Posted by TLSAnthracite
well press the button that makes the air circulate inside the car or press it twice, that should turn off the auto light.
rockyboy
12-06-2022 02:29 PM
mada51589
05-03-2022 08:54 PM
