Bumpy Ride?
Old Sep 16, 2004 | 08:31 PM
tom99tl's Avatar
Bumpy Ride?
Was just driving through the DC city streets today and man my car was jumping around like crazy. I also noticed this on other bumpy roads. Is this a problem with the struts? Do you think bad rotors can cause this rough ride? My ride seems rough even on smooth roads.
Old Sep 16, 2004 | 09:13 PM
Tom Blasing's Avatar
is the Mighty Favog
Check your tire pressure when their cold. If it's up around 38-40lbs. it could do this. The struts are probably fine unless you have a zillion miles on them or the car was in a front end wreck. You may want to have the allignment and tire balance checked too. As a DIY you could swap the front tires for the back ones and see if it feels different.
Also, if your not used to V, W or Z rated tires it could feel rough. The side walls are pretty stiff on the Michelins especially.
Old Sep 16, 2004 | 09:16 PM
darkfox12's Avatar
NBP and lovin it
Yea like tom said, get allignment and tire balance done, that may help a little bit and i dont think it would be the struts, unless they blew out somehow or something.
Old Sep 17, 2004 | 03:35 PM
tom99tl's Avatar
thanks. i usually have my tires at 32/33. i've had the tires balanced and aligned and they're brand new. maybe the tires are no good? i got pirelli P6s on the front and kumho ecstas on the rear.
neuronbob
23
Jul 16, 2019 10:48 AM
emailnatec
29
Sep 28, 2018 04:27 PM
ceb
ILX
Sep 27, 2015 10:56 AM
kencepeda
Sep 26, 2015 05:13 PM
4drviper
Sep 23, 2015 07:42 PM
