Bulb installation
Old May 2, 2004 | 10:29 AM
Diesel_Blue_TL's Avatar
Bulb installation
I got a new set of bulbs and only installed one of them (only one blew out ) and not i'm getting a gleam of light that seems brighter and goes further then my stock bulb. Is there any specific way of installing the bulb?
Old May 2, 2004 | 10:34 AM
asloudasitgets's Avatar
wow, maybe you should explain which bulb your talking about first?
Old May 2, 2004 | 10:59 AM
Mr Hyde's Avatar
Old May 2, 2004 | 11:04 AM
Bxscig's Avatar
I would assume you mean the low beam HIDs.... well, you might have to re-aim the headlights. I know when I put my 6000Ks in, the alignment was ALL off. I parked it away from a wall and the then aligned it.
Old May 2, 2004 | 11:44 AM
Mr Hyde's Avatar
That doesnt make sense. Just changing a low beam bulb should not change your headlight alignment unless the bulb is not seated correctly. I would remove that bulb, and reinstall it again.
Old May 2, 2004 | 08:00 PM
Bxscig's Avatar
I had a hard time getting it in so maybe I moved something. I definitely didn't touch that bolt that is used for aimming though. Another time was when I removed the headlights for clearing.
Old Jan 13, 2008 | 11:24 AM
innovation704's Avatar
is there a diy on changing and installing hid bulbs on the 2nd gen tl?
Old Jan 13, 2008 | 11:34 AM
01tl4tl's Avatar
yes in the DIY section!
https://acurazine.com/forums/showpos...89&postcount=2
Make sure the bulb went in the exact same way the old one came out- meaning the electrode wire on the outside was pointed up and the base clip held the bulb in flat.
Since you had to work it to fit- remove and inspect that external 'trode and its shield for any breakage
If you removed the entire housing before, its possible they didnt go exactly back in the same place- there is a little room there- thats why headlights are adjustable
What bulbs did you get? brand name- K rating and were they brand new in a box?
Old Jan 13, 2008 | 11:37 AM
01tl4tl's Avatar
NOTE: always replace bulbs in pairs as the output intensity will be way different between new and old- epecially on HID low beams
This applies to taillight-brakelight-turn signal bulbs too.
If one went- how far behind can the other be?
Old Jan 13, 2008 | 12:29 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
Always change bulbs in pairs. You did one, why not the other? Keep things balanced.
Old Jan 13, 2008 | 03:22 PM
imprezagtr's Avatar
changing them aren't that hard, and since you did mention that the new one worked, so it just means you probably got the wrong bulb. the TL uses D2R or D2S (D2S is backward compatible with D2R). I got mine for $200 a pair, the Japanese ones. But the ebay ones for under $100 should work as well.
And make sure you get the right temperature - 6K is the most recommended one, anything higher is just for show, not practical at all.
Old Jan 13, 2008 | 05:32 PM
fsttyms1's Avatar
and 4300 is stock and the brightest most usable light
Old Jan 13, 2008 | 06:09 PM
01tl4tl's Avatar
c'mon Kris- admit it- you like the Kaixen 6000k blue tint now ~
isnt it better to see where the edge of the road is--- than to see brighter directly in front of the car- when its too late for evasive action?
Old Jan 13, 2008 | 06:10 PM
01tl4tl's Avatar
Acurazine Vendor Excelerate has the good bulbs and is putting together a group buy on them right now- see Sponsored Sales area
200? thats too much- Kaixens are under 150 a pair and the industry leaders in technology
Old Jan 17, 2008 | 05:06 PM
pizz419's Avatar
Wish it was dropped.....
i got the 5,000K Kaixen's just the other day and so far i love them! contact Excelerate!
Old Jan 17, 2008 | 06:05 PM
AMGala's Avatar
Lamborghini Aventador FTW
I love all of these posts years after the thread was made. And I hate them at the same time.
BoricuaTL
Apr 8, 2016 01:08 PM
InFaMouSLink
Oct 27, 2015 06:51 PM
dirleton
Sep 18, 2015 05:25 PM
TxRzrBk
Sep 17, 2015 01:07 PM
Greengecko
Sep 16, 2015 08:19 PM
