Broken outboard boot at front axle! what solution?
Old Nov 8, 2013 | 08:56 PM
hugous's Avatar
Hi guys!
When I do the oil change today, I found that the outboard boot of the driveshaft at passenger side was broken. It cause the grease to leak around control arms. So I wonder if I need to replace the boot or I have to replace the whole right axle? I found the CV boot kit on amazon but not so sure it will fit TL. Anyone tried that? Here's the boot kit:
Amazon.com: Dorman HELP! 614-632 C Series Universal Quick Boot Kit: Automotive Amazon.com: Dorman HELP! 614-632 C Series Universal Quick Boot Kit: Automotive
Old Nov 8, 2013 | 09:45 PM
ErickUa5's Avatar
Mr.Helpful Diagram
Honestly go for a new one that axle is probably on its way since all the grease is not being held in. If theres one thing I learned about axles is to never go with reman stuff nothing but headaches. That would be my advice hope it helps ya.
Old Nov 8, 2013 | 09:49 PM
Yikes's Avatar
I would advise just getting a new axle. Replacing a CV boot will prove to be a massive pain in the ass, and it is a lot easier to pull the axle and put a new one on.
Old Nov 8, 2013 | 11:42 PM
3.2TLc's Avatar
Hey Hugous, while it's possible to replace the axle's CV boot, don't bother with the unistyle kit. If you're able to do the labor yourself and ya know that the CV bearing joint is still good, then clean....relube and install an OEM style replacement boot. Less then $50 and your DIY time.
But, if you're paying a shop to do the work, then either buy a new complete axle assembly or a high quality reconditioned part to replace the old one with. Depending on the price of the axle, figure less then $300.
Old Nov 9, 2013 | 02:23 AM
Skirmich's Avatar
Just by looking at the boot I already know its a bad idea.... Do the AXLE the right way and dont look back.
Old Nov 9, 2013 | 11:03 PM
01tl4tl's Avatar
the grease has leaked out = the bearing is toast!!
must replace complete driveshaft assembly,,comes as new shaft, 2 new bearings and new boots
napa has good ALL NEW PARTS units,,used to be 75$..call them
Old Nov 10, 2013 | 05:18 PM
ErickUa5's Avatar
Mr.Helpful Diagram
Highly recommend napa axles although there price is $100 here in NY. One of my customers went with an autozone axle in his 99 TL for $75 recently lets see how it will hold up.
Feb 25, 2020 09:57 AM
jblessing
Aug 8, 2018 09:43 PM
marcelft
Jul 10, 2018 06:17 PM
BKSleeper
Oct 7, 2015 10:20 AM
08 NBP TL
Sep 8, 2015 08:49 PM
