braking issues
Originally posted by tls260:
I recently purchased a 2002 tls and noticed the brakes feel soft, mushy and some what unresponsive initially. Does any one else have this problem?????
<FONT COLOR="#800080" SIZE="1" FACE="Verdana, Arial">[This message has been edited by Steveb on May 05, 2001 @ ]</font>
Not a Blowhole
The TL-S does nt overboost its power brakes. Boost is not an indicator of braking power, but can give that impression.
Acura (Honda) tends to go the way of valuing progression in brakes. That is, as you press harder, the brakes linearly increase stopping power, as opposed to an initial extra boost.
Progressive braking is esteemed in racing venues because it gives the driver a very good feel for braking.
The TL-S has different pad material, and does seem to want to be "heated" a but before it grabs real well.
In a panic stop, the pad material heats instantly, so I think this is more a perceptual than a functional issue.
If you want to feel soft brakes go drive a Subaru Outback. We have one and pedal feels like it is going to it the floor board before the brakes grab. When i drive the Outback after the TL-S I have a major adjustment
Ain't No Other...
Not a Blowhole
Note the subtle use of the word "tends" my friend - I never said all. BS as adjective tends to suggest that the writer either has no technical grasp of the subject or is lying to achieve a desired end - I assure you, that does not apply to me.
Luxury cars often have overboost just to give the perception you noted. This is fine for cars that are seldomly driven hard - it is never good for cars driven on the track or in high-perf street use. And it is not an indicatoir of ultimate brake performance, If it were, the RL would stop in a shorter distance than the RL, and be more resistant to fade. Based on what I have seen, it does neither.
MB-Fanatic w/TL-S
1 Post
My braking seems to be improved also. Brake/Tire is just like the engine, they need to be broken-in, too. However, I have to admit that TL-S' braking power is a bit weak, for so much HP....
Andy Kuo
'92 Mercedes-Benz 400SE
Pearl Grey/Black
'02 Acura TL-S
Satin Silver/Ebony, w/out NAV
Mercedes-Benz S-Class
Andy Kuo
Pearl Grey/Black
'02 Acura TL-S
mada51589
05-03-2022 08:54 PM
