Brakes worn uneven
Old Mar 15, 2007 | 01:07 PM
2000tl32's Avatar
Brakes worn uneven
Hey guys,
Few days ago, I noticed a click sound while applying the brakes to bring the car to a full stop after reversing. Then I noticed the same some noise when I applied the brake to bring the car to a full stop in drive mode. I only hear this when coming to a full stop when revising and coming to a full stop after the revise.
I took the front passenger brake out, and I noticed that the top and bottom of the brake is alomost to the metal. I would I have about 10 % pad left on the top and bottom part of the brake, but I have more than 50% pad left in the center of the pad.
Has anyone else had this problem?
Old Mar 15, 2007 | 01:16 PM
Blazin_TL's Avatar
Registered User
check caliper piston, it could be seized
Old Mar 15, 2007 | 03:14 PM
JMAL's Avatar
sounds about right, also make sure the caliper moves freely on the pin and that its lubricated. was the caliper securely attached to the car or did it have play?
Old Mar 15, 2007 | 07:12 PM
Blazin_TL's Avatar
Registered User
if you drive around for a little while and let the caliper get hot you can jack up that side and just spin the wheel and see if there is any friction
Old Mar 17, 2007 | 01:08 PM
2000tl32's Avatar
here is a pic of the brake.
Old Mar 17, 2007 | 02:06 PM
JMAL's Avatar
that might just be the pad design. that looks impossible to be from driving wear.
Old Mar 17, 2007 | 04:26 PM
BOSSIN$TL's Avatar
ZK.TBK.SCR.BIA.X408
for some reason 99-like 02 have a few minorproblems some i encountered and some i heard about. horrible brakes is one thing i've heard about. and i have a 99 TL also and i can feel my brakes are in bad condition too.
Old Mar 17, 2007 | 06:44 PM
01tl4tl's Avatar
When you said uneven wear- many of the groups answers were based on inner pad versus outer pad wear, thats a bad thing.
What you have is the forces of braking at work.
The weight transfers forward under braking
Get some Hawk HPS and be done with it
www.hawkperformance.com for tech details
Old Mar 18, 2007 | 02:13 AM
Lawaia's Avatar
Moderator Alumnus
There's nothing wrong with that pad in the pic. The edges of the pad are chamfered to reduce brake noise, and is usually done on the leading edge only.
Old Mar 18, 2007 | 04:50 AM
MikePA's Avatar
That's a picture of the brake pad, not the brake.
Old Mar 20, 2007 | 05:32 PM
heehaaw's Avatar
yeah thats totally normal. thats how they look when they're new.
Old Mar 22, 2007 | 10:45 AM
fla-tls's Avatar
On the way!
I don't know where you're getting those 10%/50% numbers from. That pad looks almost brand new - with no uneven wear. Have you ever done brakes before? You may want to have someone who knows what they're doing help you out. We don't a fellow a-zine member working on their brakes incorrectly and getting in an accident.
Old Mar 22, 2007 | 11:36 AM
2000tl32's Avatar
Well, I have done brake work before, but I have never paid attention to the shape of the pad. The reason why I panic was because the clicking sound. I appreciate your all concerns.
Old Mar 22, 2007 | 11:54 AM
fla-tls's Avatar
On the way!
Yeah - my GF has that clicking sound from her front pads as well. It's just the pads sliding back and forth a bit on the calipers. It's nothing to worry about. Some new brake hardware can help fix that. You can find brake hardware to hold the pads tight in the caliper in any auto parts store.
I also put my pads in with no shims over them (unless they come with something like the green stuff pads do), but use brake anti-squeal on the outer pad. Don't use too much - two little dabs where the pad holder meets the pad is all you need.
GWEEDOspeedo
Jan 15, 2016 10:39 PM
rockyboy
Oct 2, 2015 10:45 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
2ManyHobbies
Sep 24, 2015 09:23 PM
Brandle34
Sep 23, 2015 07:20 PM
