Brakes-Steering Need Help
Old Dec 8, 2004 | 12:10 PM
Black Tl-S's Avatar
Hi Guys,
I need some advice, My tl-s need front brakes very very soon. I was wondering if i should change them myself. I haven't changed the brakes for a Tl-s before.Other then that when i steer my steering at a particular angel it makes a squeaking sound as if something is dry.It comes from inside on the car. Any idea??
please advise!
Old Dec 8, 2004 | 10:54 PM
vipvop's Avatar
I had an issue with my wheel where when I turned sometimes there'd be a horrible squealing sound, turned out to be busted wheel bearings.
as for brake pads, everyone says they're easy to change by yourself, I always just go to the mechanic anyway (dont have a good jack or anything like that, and Im not going to bother with the crappy stock jack).
Old Dec 9, 2004 | 12:53 AM
TeknoKing's Avatar
if you have the time, you can definitely do it, the hardest part is jacking up the car.
here is a http://www.akuraworld.com/forums/sho...threadid=19636 k=c
Old Dec 13, 2004 | 12:36 PM
Black Tl-S's Avatar
Thanks guys. I think i will try to change them my self. When i start my car and drive it it makes this weird loud sound like eeemmmmmmrrrrgghhhh twice and thats it. the dealership told me that it does that to build brake pressure. is that right?
Old Dec 13, 2004 | 01:04 PM
Pure Adrenaline's Avatar
Dragging knees in
The two "grrrr" noises are your ABS and VSA running a self-diagonstics test. The first one is the ABS pressurizing the system (so yeah, the dealership was right), and the second noise is the VSA (you wouldn't have this noise on the Premium models because there's no VSA).
Absolutely nothing to worry about. In fact, if you did NOT hear those two noises, then you should be worried.
Old Dec 13, 2004 | 01:07 PM
fsttyms1's Avatar
non vsa cars do it also mine does
but yea its normal
Old Dec 13, 2004 | 01:11 PM
Dragging knees in
but yea its normal
D'oh! I forgot that the TCS would do the same thing. My fault.
Old Dec 13, 2004 | 01:13 PM
fsttyms1's Avatar
ehehehehehe
Old Dec 13, 2004 | 01:24 PM
Dragging knees in
ehehehehehe
Yeah, yeah, laugh it up, Kris. I'm gonna remember this next time I spot a mistake from ya. Then I'm gonna let you have it.
Old Dec 13, 2004 | 01:41 PM
fsttyms1's Avatar
it will never happen!
Old Dec 13, 2004 | 01:56 PM
Dragging knees in
If I ever made moderator, the first thing would be edit your post with the wrong information, then proceed to make fun of you.
Old Dec 13, 2004 | 02:27 PM
fsttyms1's Avatar
haha you would!
Old Dec 15, 2004 | 10:35 AM
Black Tl-S's Avatar
Thank you guys. The info is very knowledgeable. I have seen people with the Vtec controller installed. what is that and how much horse power does that give.
Old Dec 15, 2004 | 11:37 AM
TeknoKing's Avatar
it allows to you control the Vtec kickin in time along with outher triggered options......in other words gives you more control of the engine and its output when you want it...its not a horsepower gainer.
Old Dec 15, 2004 | 03:28 PM
Dragging knees in
It allows you to adjust air/fuel ratio, and change VTEC engagement/disengagement point to help smooth out the power.
It's not a major power adder; rather, its purpose is to make the powerband smoother. It has to be dynotuned by a professional.
On top of adjustments, it can also display real-time data.
Old Dec 15, 2004 | 04:33 PM
Black Tl-S's Avatar
Is it woth it to get this device???
Which is a good website to search for accessories for my car?
Old Dec 16, 2004 | 12:26 AM
whatwasthat's Avatar
ah... what noise are you guys talking about?? when i start the car, i only hear the fan and a/c compressor... and intake... no eeeemmmmmrrrrggghhhhh sound.. should i be worried?
Old Dec 16, 2004 | 04:25 AM
Dragging knees in
The self-diagonistics tests are only initiated once you start driving. It's in your owner's manual. It will tell you which test is done at which speed.
